got a problem with my LibreNMS.
Looks like the poller is running regularaly, but not writing any kind of data to MySQL of RRD.
The WebUI also says that polling of devices hasn’t completed the last 15 minutes.
Output of validate:
bash-4.2$ ./validate.php
LibreNMS | 1.63-139-g73e2649
DB Schema | 2020_04_06_001048_the_great_index_rename (165)
PHP | 7.2.14
Python | 3.6.8
MySQL | 5.5.65-MariaDB
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
[OK] Composer Version: 1.10.6
bash-4.2$
When running
./poller.php -h 4050-testfloor-5142-1
it results in following:
bash-4.2$ ./poller.php -h 4050-testfloor-5142-1
LibreNMS Poller
Starting polling run:
Hostname: 4050-testfloor-5142-1
Device ID: 80
OS: ciena-sds
Resolved IP: 172.25.0.4
#### Load poller module core ####
Uptime: 180 days 17 hours 2 minutes 54 seconds
>> Runtime for poller module 'core': 0.0615 seconds with 46800 bytes
>> SNMP: [2/0.06s] MySQL: [0/0.00s] RRD: [1/0.00s]
#### Unload poller module core ####
#### Load poller module unix-agent ####
>> Runtime for poller module 'unix-agent': 0.0005 seconds with 8248 bytes
>> SNMP: [0/0.00s] MySQL: [0/0.00s] RRD: [1/0.00s]
#### Unload poller module unix-agent ####
#### Load poller module os ####
Generic :(
Hardware:
OS Version:
OS Features:
Serial:
>> Runtime for poller module 'os': 0.0355 seconds with 255936 bytes
>> SNMP: [1/0.03s] MySQL: [0/0.00s] RRD: [1/0.00s]
#### Unload poller module os ####
#### Load poller module ipmi ####
>> Runtime for poller module 'ipmi': 0.0010 seconds with 35416 bytes
>> SNMP: [0/0.00s] MySQL: [1/0.00s] RRD: [1/0.00s]
#### Unload poller module ipmi ####
#### Load poller module sensors ####
>> Runtime for poller module 'sensors': 0.0006 seconds with 1464 bytes
#### Unload poller module sensors ####
#### Load poller module processors ####
>> Runtime for poller module 'processors': 0.0017 seconds with 58192 bytes
#### Unload poller module processors ####
#### Load poller module mempools ####
>> Runtime for poller module 'mempools': 0.0006 seconds with 1792 bytes
#### Unload poller module mempools ####
#### Load poller module storage ####
>> Runtime for poller module 'storage': 0.0006 seconds with 1792 bytes
#### Unload poller module storage ####
#### Load poller module netstats ####
ICMP IP IP-FORWARD SNMP TCP TCPHC UDP
>> Runtime for poller module 'netstats': 0.2841 seconds with 4120 bytes
>> SNMP: [7/0.28s] MySQL: [0/0.00s] RRD: [6/0.00s]
#### Unload poller module netstats ####
#### Load poller module hr-mib ####
>> Runtime for poller module 'hr-mib': 0.0331 seconds with 1552 bytes
#### Unload poller module hr-mib ####
#### Load poller module ucd-mib ####
>> Runtime for poller module 'ucd-mib': 0.0971 seconds with 2864 bytes
>> SNMP: [3/0.10s] MySQL: [0/0.00s] RRD: [1/0.00s]
#### Unload poller module ucd-mib ####
#### Load poller module ipSystemStats ####
ipv4 ipv6
>> Runtime for poller module 'ipSystemStats': 0.0641 seconds with 17360 bytes
>> SNMP: [1/0.06s] MySQL: [0/0.00s] RRD: [3/0.00s]
#### Unload poller module ipSystemStats ####
SNMP [35/2.36s]: Get[11/0.38s] Getnext[4/0.13s] Walk[20/1.86s]
MySQL [159/0.08s]: Cell[49/0.02s] Row[-48/-0.02s] Rows[33/0.03s] Column[0/0.00s] Update[111/0.05s] Insert[14/0.01s] Delete[0/0.00s]
RRD [70/0.01s]: Update[70/0.01s]
bash-4.2$
I stripped some lines in the middle to shorten it a liitle bit.
Anyone an idea what goes wrong?
