./validate.php
| LibreNMS | 23.7.0-12-g65e3edd13 (2023-07-20T09:37:04-07:00) |
| DB Schema | 2023_04_27_164904_update_slas_opstatus_tinyint (252) |
| PHP | 8.2.7 |
| Python | 3.8.10 |
| Database | MariaDB 10.3.38-MariaDB-0ubuntu0.20.04.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.8 |
[OK] Composer Version: 2.5.8
[OK] MySQl and PHP time match
https://p.libren.ms/view/4da93186
I have several rules that are not functioning with just one of my nodes. I have several nodes they are all identical minus IPs and SNMP port and they are working fine with no issues.
I noticed the rules have “Status: SKIP” when ever I run poller.
I have verified services are running on the node.
I had to change the SNMP port because for some odd reason the provider in that location blocks normal SNMP ports.
Is there a way to force a re-enable of the rule or re-read configuration?
I have gone through all the Config → Modules turned off everything ran poller and snmp manually. Then turned back on all modules and ran poller and snmp manually and still same thing.
`Rule #18 (API Proxy Service: Gunicorn):
SQL[SELECT * FROM devices,processes WHERE (devices.device_id = ? AND devices.device_id = processes.device_id) AND processes.command LIKE ‘unicorn%’ [1100] 0.76ms]
SQL[SELECT state FROM alerts WHERE rule_id = ? AND device_id = ? ORDER BY id DESC LIMIT 1 [18,1100] 0.51ms]
Status: SKIP
Rule #19 (API Proxy Service: Nginx):
SQL[SELECT * FROM devices,processes WHERE (devices.device_id = ? AND devices.device_id = processes.device_id) AND processes.command LIKE ‘ginx%’ [1100] 0.73ms]
SQL[SELECT state FROM alerts WHERE rule_id = ? AND device_id = ? ORDER BY id DESC LIMIT 1 [19,1100] 0.5ms]
Status: SKIP
Rule #20 (API Proxy Service: Squid):
SQL[SELECT * FROM devices,processes WHERE (devices.device_id = ? AND devices.device_id = processes.device_id) AND processes.command LIKE ‘%squid%’ [1100] 0.99ms]
SQL[SELECT state FROM alerts WHERE rule_id = ? AND device_id = ? ORDER BY id DESC LIMIT 1 [20,1100] 0.46ms]
Status: SKIP’
