I ran an update and now my NMS stopped polling, it used to poll every 5mins. I am pretty new to librenms so i’m not sure where to look. Kindly assist.
[FAIL] The poller (xx) has not completed within the last 5 minutes, check the cron job.
[xx]# ./daily.sh
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
Email Error
Cronic detected failure or error output for the command:
/opt/librenms/poller-wrapper.py 23
RESULT CODE: 2
ERROR OUTPUT:
STANDARD OUTPUT:
ERROR: Could not load or parse configuration, are PATHs correct?
I have the same problem but no devices are being polled even after 2 hours. I have checked the log and no errors are visible, New to librenms please help
