gonzo
23 February 2022 09:51
#1
We have a LibreNMS server and 1 poller, but polling is very intermittent on all devices, can you help/advise please?
LibreNMS | 22.2.1-6-g703745d0e
DB Schema | 2022_02_03_164059_increase_auth_id_length (235)
PHP | 7.4.3
Python | 3.8.10
MySQL | 10.3.32-MariaDB-0ubuntu0.20.04.1
RRDTool | 1.7.2
SNMP | 5.8
[OK] Composer Version: 2.2.6
[INFO] Detected Dispatcher Service
[FAIL] Missing PHP extension: memcached
Please install memcached
Modified Files:
includes/definitions/rutos.yaml
rrd/.gitignore
This how all the CPU, Mem, network graphs look on all devices. This is one of the graphs for the LibreNMS server itself (local).
The poller is in Docker, I’m not sure how to validate it.
bash-5.1# cd /opt/librenms/
bash-5.1# ./validate.php
Do not run validate.php as root
What could be wrong?
I think there are some sync problems between pollers. Are you using redis? memcached ? Is it configured correctly.
Second, i think number of workers are not enough. What happens if you increase the number ?
As best practice, for 1k+ devices, I would skip docker. Just me feelling here.
gonzo
23 February 2022 16:19
#3
Does that cluster health look bad then?
I thought I had memcache installed but says:
How do I check and install?
I’m sure it ran better without the poller how can I check if they are syncing properly?
Noticed this too in the Global settings, should this be enabled?
Also what config(s) can I share that might help you understand the setup?
My experience with docker is almost none.
Can you validate the config from the web interface?
gonzo
23 February 2022 18:20
#5
I’m tempted to remove this docker poller then.
I’ve restarted both VMs and it seems a little quicker, but it seems quicker with the poller off. However the graphs are still bad.
With the poller off and via CLI I see
I’m not sure where to start on this.
gonzo
23 February 2022 18:45
#6
I see this a lot too. I’ve turned that poller back on.
For unknown reason your cluster is not capable to handle all polling in the configured timeframe (5 minutes standard).
If configuration is fine (not sure about this), take a look into this .
gonzo
23 February 2022 19:32
#8
I’ll go through this and get back to you.
To increase the workers where do I go for this?
I didn’t set all of this up so it’s hard and I’m under pressure to get it working so thanks for helping.
If the configuration is not changed in the config file than it can be done in the web interface.
gonzo
23 February 2022 21:36
#10
I can post the config if you like maybe you will notice something odd?
gonzo
24 February 2022 09:49
#11
I ran the MySQL tuner, anything jump out?
https://pastebin.com/4sRe6SXe
How do I increase the workers and SQL connections?
system
Closed
25 May 2022 09:49
#12
