Is there a way to get the port graphs, specifically the port_bits graph to set the y-axis based on interface speed instead of auto-scaling to max value?
We are attempting to utilize the graphs to give us a quick glance of utilization percentage across multiple links. Using the port types. Unfortunately when a low utilized link, like a backup, is scaled down it appears like it is being maxed when next to the active link. The active link is showing Mbits and the backup link is showing in bits…
