On the GUI when I check under ports menu the count of error, down ports are not displayed.
How do I fix this?
Component |
Version |
LibreNMS |
1.63-56-g27cc5ac |
DB Schema |
2020_04_19_010532_eventlog_sensor_reference_cleanup (165) |
PHP |
7.3.18 |
Python |
3.6.9 |
MySQL |
5.5.62 |
RRDTool |
1.3.8 |
SNMP |
NET-SNMP 5.5 |
[OK] Composer Version: 1.10.7
[WARN] Your database schema has extra migrations (2020_04_06_001048_the_great_index_rename). If you just switched to the stable release from the daily release, your database is in between releases and this will be resolved with the next release.
Could it be possible that you did a version rollback?
I think it should fix with a ./daily.sh but not sure tbh
I tried running ./daily.sh multiple times. Tried rebooting the VM as well.
Nothing work so far.
Is there any reason you are not updating your install?
I am not sure what do you mean by not updating your install?
I have setup update to run everyday and on stable release. Not sure how to fix the db warning.
Release is 1.64 and you are in 1.63
./daily.sh
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
./validate.php
Component |
Version |
LibreNMS |
1.63-56-g27cc5ac |
DB Schema |
PHP |
7.3.18 |
Python |
3.6.9 |
MySQL |
5.5.62 |
RRDTool |
1.3.8 |
SNMP |
NET-SNMP 5.5 |
I tried manually running daily.sh again and did the validation.
It does not look like the new version is getting updated.
Do you have access to internet from this server ?
Could you show us the result of “git status” ?
Thanx
Yes, the server has access to the internet.
git status
On branch php71-python2
Your branch is up-to-date with 'origin/php71-python2'.
nothing to commit, working tree clean
The issue got resolved
used php artisan view:clear
@murrant thanks for assist.
