Port Detail only show on port is polling and alerting
Hello, I noticed that when I click on a device’s port, the port details only display those with both Disable Polling = OFF and Ignore Alert Tag = OFF. Would it be possible to adjust this so that it only considers Disable Polling = OFF, without referencing the Ignore Alert Tag? The reason is that for some ports, we only want to collect statistics and status data, but do not need alerts when an issue occurs.
Please kindly have the developers review this and see if an adjustment can be made. Thank you!
