Port Duplication
I am running a site-to-site unifi setup over openvpn.
The ISP is not very stable at the remote site and drops out every now and then.
After reconnection the port shows up in Librenms with a new port ID and a duplicate.
It states all ports are up, which is not true.
There is only one vtun64.
See attached picture…
Any suggestion??
It makes it hard to monitor the tunnel based traffic when the ID is changing on the interface after a reconnect.
EDIT: typos
Edit your device and in SNMP set Port Assoc to the one you need:
Thanks Doc!
It was what i was looking for!
Thanks a lot
