Port-Status notification
Hi Guys,
For Port status up/down notification does it use trap system? or snmp read?
I’ve an Arista switch where most of the ports are down, how can I move them out so Librenms won’t trigger the alert, can I adjust it from the switch itself ?
snmp read.
You need to update the rule to exclude the ports you don’t want using ifName, ifDescr, or something similar (or set the ports to ignored).
What will be the right Entity to exclude ifdescr?
I was trying to use the following alert, where part of my description on the ports I added RISK0 word, but it’s still not working please advise
You’ve chosen equals there, you need like and then to use mysql regex or the wildcard @ for replacements. The docs cover this.
Got it, thanks it works
