Hi all.
Has anyone here set up altering for postfix?
queue and etc…
Hi all.
queue and etc…
for example like this for deferred email’s
SELECT * FROM devices,applications,application_metrics WHERE (devices.device_id = ? AND devices.device_id = applications.device_id AND applications.app_id = application_metrics.app_id) AND applications.app_type = “postfix” AND application_metrics.metric = “deferredq” AND application_metrics.value >= 100
I will test and revert.
Thank you very much!
app_type is postfix
You need to more specify which one metric do you want for alert, for example like me where i specified deferredq
you can look at metric in mysql with
SELECT * FROM applications,application_metrics WHERE applications.app_type = "postfix";
when you want for queue, than you need specify which one
there is
MariaDB [librenms]> SELECT * FROM applications,application_metrics WHERE applications.app_type = "postfix" AND application_metrics.metric = "deferredq";;
| app_id | device_id | app_type | app_state | discovered | app_state_prev | app_status | timestamp | app_instance | app_id | metric | value | value_prev |
| 6 | 34 | postfix | OK | 1 | UNKNOWN | | 2019-05-20 13:03:03 | | 6 | deferredq | 10 | 11 |
1 row in set (0.00 sec)
ERROR: No query specified
MariaDB [librenms]> SELECT * FROM applications,application_metrics WHERE applications.app_type = "postfix" AND application_metrics.metric = "holdq";;
| 6 | 34 | postfix | OK | 1 | UNKNOWN | | 2019-05-20 13:03:03 | | 6 | holdq | 0 | NULL |
MariaDB [librenms]> SELECT * FROM applications,application_metrics WHERE applications.app_type = "postfix" AND application_metrics.metric = "activeq";;
| 6 | 34 | postfix | OK | 1 | UNKNOWN | | 2019-05-20 13:03:03 | | 6 | activeq | 0 | 3 |
MariaDB [librenms]> SELECT * FROM applications,application_metrics WHERE applications.app_type = "postfix" AND application_metrics.metric = "incomingq";;
| 6 | 34 | postfix | OK | 1 | UNKNOWN | | 2019-05-20 13:03:03 | | 6 | incomingq | 0 | 1 |
so I want to alert when a certain amount to mails are coming in to my queue
as this server is smtp so it should only be sending mail
I edited my last post, check it
