Hello again,
I cant see any errors but also can
t see postgres module.
I attached the result of the command.
LibreNMS Poller
SQL[select migration
from migrations
order by id
desc limit 1 [] 0.69ms]
SQL[select count(*) as aggregate from migrations
limit 1 [] 0.54ms]
SQL[SELECT version() [] 1.02ms]
Version info:
Commit SHA: 83dd1f0a167f0a44fa992477d31a34893885d909
Commit Date: 1588001024
DB Schema: 2020_04_13_150500_add_last_error_fields_to_bgp_peers (164)
PHP: 7.2.16-1+ubuntu16.04.1+deb.sury.org+1
MySQL: 10.0.38-MariaDB-0ubuntu0.16.04.1
RRDTool: 1.5.5
SNMP: NET-SNMP 5.7.3
Updating os_def.cache…
Done
Override poller modules: applications
Starting polling run:
SQL[SELECT * FROM devices
WHERE disabled
= 0 AND hostname
= ‘192.168.13.100’ ORDER BY device_id
ASC [] 0.87ms]
SQL[select * from information_schema.tables where table_schema = ? and table_name = ? and table_type = ‘BASE TABLE’ [“librenms”,“migrations”] 0.57ms]
from migrations
[] 0.47ms]
SQL[select distinct os
from devices
[] 0.69ms]
SQL[select * from devices
where device_id
= ? limit 1 [44] 0.67ms]
SQL[select * from devices_attribs
where devices_attribs
.device_id
= ? and devices_attribs
.device_id
is not null [44] 0.34ms]
Hostname: 192.168.13.100
Device ID: 44
OS: linux
(unix)
SQL[select hostname
, overwrite_ip
from devices
where hostname
= ? limit 1 [“192.168.13.100”] 0.61ms]
[FPING] ‘/usr/bin/fping’ ‘-e’ ‘-q’ ‘-c’ ‘3’ ‘-p’ ‘500’ ‘-t’ ‘500’ ‘192.168.13.100’
array (
‘xmt’ => 3,
‘rcv’ => 3,
‘loss’ => 0,
‘min’ => 0.59,
‘max’ => 1.25,
‘avg’ => 0.86,
‘dup’ => 0,
‘exitcode’ => 0,
SQL[INSERT IGNORE INTO device_perf
(xmt
,rcv
,loss
,min
,max
,avg
,device_id
,timestamp
,debug
) VALUES (:xmt,:rcv,:loss,:min,:max,:avg,:device_id,NOW(),:debug) {“xmt”:3,“rcv”:3,“loss”:0,“min”:0.59,“max”:1.25,“avg”:0.86,“device_id”:44,“debug”:"[]"} 0.66ms]
SQL[UPDATE devices
set last_ping
=?,last_ping_timetaken
=? WHERE device_id=? [“2020-04-28 16:05:31”,0.86,44] 0.82ms]
SNMP Check response code: 0
Modules status: Global+
OS
Device
Load poller module core
SNMP[’/usr/bin/snmpget’ ‘-v1’ ‘-c’ ‘COMMUNITY’ ‘-OQnUt’ ‘-m’ ‘SNMPv2-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell’ ‘udp:HOSTNAME:161’ ‘sysUpTime.0’ ‘sysLocation.0’ ‘sysContact.0’ ‘sysName.0’ ‘sysObjectID.0’ ‘sysDescr.0’]
...0 = 1853139
...0 = Sitting on the Dock of the Bay
...0 = Me [email protected]
...0 = postgresmontosa
...0 = ..4.1.8
...0 = Linux postgresmontosa 4.9.0-3-amd64 #1 SMP Debian 4.9.30-2+deb9u5 (2017-09-19) x86_64
SNMP[’/usr/bin/snmpget’ ‘-v1’ ‘-c’ ‘COMMUNITY’ ‘-OQnUst’ ‘-m’ ‘HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell’ ‘udp:HOSTNAME:161’ ‘snmpEngineTime.0’ ‘hrSystemUptime.0’]
hrSystemUptime.0 = 122214360
Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: snmpEngineTime.0
Uptime seconds: 1222144
InfluxDB data: {“measurement”:“uptime”,“tags”:{“hostname”:“192.168.13.100”},“fields”:{“uptime”:1222144}}
RRD[update 192.168.13.100/uptime.rrd N:1222144 --daemon unix:/var/run/rrdcached.sock]
Uptime: 14 days 3 hours 29 minutes 4 seconds
SQL[select * from locations
where (location
= ?) limit 1 [“Sitting on the Dock of the Bay”] 0.44ms]
Runtime for poller module ‘core’: 0.0453 seconds with 131400 bytes
SNMP: [2/0.03s] MySQL: [0/0.00s] InfluxDB: [1/0.00s] RRD: [1/0.00s]
Unload poller module core
InfluxDB data: {“measurement”:“poller-perf”,“tags”:{“hostname”:“192.168.13.100”,“module”:“core”},“fields”:{“poller”:0.04529285430908203}}
RRD[update 192.168.13.100/poller-perf-core.rrd N:0.045292854309082 --daemon unix:/var/run/rrdcached.sock]
OS
Device
Load poller module applications
SQL[SELECT * FROM applications
WHERE device_id
= ? [44] 0.66ms]
postgresSNMP[’/usr/bin/snmpwalk’ ‘-v1’ ‘-c’ ‘COMMUNITY’ ‘-Oqv’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/supermicro:/opt/librenms/mibs/dell’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.8072.1.3.2.3.1.2.8.112.111.115.116.103.114.101.115’]
End of MIB
InfluxDB data: {“measurement”:“app”,“tags”:{“hostname”:“192.168.13.100”,“name”:“postgres”,“app_id”:“9”},“fields”:{“backends”:""}}
RRD[update 192.168.13.100/app-postgres-9.rrd N:U:U:U:U:U:U:U:U:U:U:U:U:U:U:U:U:U --daemon unix:/var/run/rrdcached.sock]
SQL[UPDATE applications
set app_state
=?,app_status
=?,timestamp
=NOW() WHERE app_id
= ? [“UNKNOWN”,"",9] 1.06ms]
SQL[SELECT * FROM application_metrics
WHERE app_id=? [9] 0.34ms]
SQL[SELECT C
.id
,C
.device_id
,C
.type
,C
.label
,C
.status
,C
.disabled
,C
.ignore
,C
.error
,CP
.attribute
,CP
.value
FROM component
as C
LEFT JOIN component_prefs
as CP
on C
.id
=CP
.component
WHERE ( C
.device_id
= ? AND C
.type
= ? ) [44,“postgres”] 0.58ms]
Runtime for poller module ‘applications’: 0.0232 seconds with 64768 bytes
SNMP: [1/0.01s] MySQL: [4/0.00s] InfluxDB: [2/0.02s] RRD: [2/0.00s]
Unload poller module applications
InfluxDB data: {“measurement”:“poller-perf”,“tags”:{“hostname”:“192.168.13.100”,“module”:“applications”},“fields”:{“poller”:0.0232241153717041}}
RRD[update 192.168.13.100/poller-perf-applications.rrd N:0.023224115371704 --daemon unix:/var/run/rrdcached.sock]
Start Device Groups
where devices
.device_id
= ? limit 1 [44] 0.65ms]
SQL[select * from device_groups
[] 0.27ms]
SQL[select devices
.device_id
, device_group_device
.device_group_id
as pivot_device_group_id
.device_id
as pivot_device_id
from devices
inner join device_group_device
on devices
.device_id
= device_group_device
.device_id
where device_group_device
.device_group_id
in (1) [] 0.72ms]
SQL[select exists(select * from devices
left join services
on devices
.device_id
= services
.device_id
where (services
.service_ip
= ? OR services
.service_ip
= ? OR services
.service_ip
= ? OR services
.service_ip
= ? OR services
.service_ip
= ? OR services
.service_ip
= ? OR services
.service_ip
= ?) and devices
.device_id
= ?) as exists
[“192.168.7.1”,“192.168.7.2”,“192.168.7.3”,“192.168.7.5”,“192.168.7.6”,“192.168.7.7”,“192.168.7.9”,44] 0.68ms]
SQL[select * from device_group_device
where device_id
= ? [44] 0.28ms]
Groups Added:
Groups Removed:
End Device Groups, runtime: 0.0117s
InfluxDB data: {“measurement”:“ping-perf”,“tags”:{“hostname”:“192.168.13.100”},“fields”:{“ping”:0.86}}
RRD[update 192.168.13.100/ping-perf.rrd N:0.86 --daemon unix:/var/run/rrdcached.sock]
InfluxDB data: {“measurement”:“poller-perf”,“tags”:{“hostname”:“192.168.13.100”,“module”:“ALL”},“fields”:{“poller”:1.173}}
RRD[update 192.168.13.100/poller-perf.rrd N:1.173 --daemon unix:/var/run/rrdcached.sock]
SQL[UPDATE devices
set uptime
=?,last_ping
=NOW(),last_ping_timetaken
=? WHERE device_id
= ? [1222144,0.86,44] 2.16ms]
Updating 192.168.13.100
Polled in 1.173 seconds
Start Alerts
where devices
.device_id
= ? limit 1 [44] 0.57ms]
SQL[select device_groups
.*, device_group_device
.device_id
as pivot_device_id
.device_group_id
from device_groups
on device_groups
.id
.device_group_id
.device_id
= ? [44] 0.75ms]
where locations
.id
= ? limit 1 [11] 0.39ms]
SQL[select exists(select * from alert_schedule
inner join alert_schedulables
on alert_schedule
.schedule_id
= alert_schedulables
.schedule_id
where ((recurring
= ? and start
<= NOW() and end
>= NOW()) or (recurring
= ? and (start_recurring_dt
<= date_format(NOW(), ‘–%d’) and (end_recurring_dt
>= date_format(NOW(), ‘–%d’) or end_recurring_dt
is null or end_recurring_dt
= ? or end_recurring_dt
= ?)) and start_recurring_hr
<= date_format(NOW(), ‘%H:%i:%s’) and end_recurring_hr
>= date_format(NOW(), ‘%H:%i:%s’) and (recurring_day
like CONCAT(’%’, date_format(NOW(), ‘’), ‘%’) or recurring_day
is null or recurring_day
= ?))) and ((alert_schedulable_type
= ? and alert_schedulable_id
= ?) or (alert_schedulable_type
= ? and 0 = 1) or (alert_schedulable_type
= ?))) as exists
[0,1,“0000-00-00”,"","",“device”,44,“device_group”,“location”,11] 2.11ms]
where devices
.device_id
= ? limit 1 [44] 0.69ms]
SQL[SELECT DISTINCT a.* FROM alert_rules a
LEFT JOIN alert_device_map d ON a.id=d.rule_id AND (a.invert_map = 0 OR a.invert_map = 1 AND d.device_id = ?)
LEFT JOIN alert_group_map g ON a.id=g.rule_id AND (a.invert_map = 0 OR a.invert_map = 1 AND g.group_id IN (SELECT DISTINCT device_group_id FROM device_group_device WHERE device_id = ?))
LEFT JOIN alert_location_map l ON a.id=l.rule_id AND (a.invert_map = 0 OR a.invert_map = 1 AND l.location_id IN (SELECT DISTINCT location_id FROM devices WHERE device_id = ?))
LEFT JOIN device_group_device dg ON g.group_id=dg.device_group_id AND dg.device_id = ?
WHERE a.disabled = 0 AND (
(d.device_id IS NULL AND g.group_id IS NULL)
OR (a.invert_map = 0 AND (d.device_id=? OR dg.device_id=?))
OR (a.invert_map = 1 AND (d.device_id != ? OR d.device_id IS NULL) AND (dg.device_id != ? OR dg.device_id IS NULL))
) [44,44,44,44,44,44,44,44] 2.01ms]
End Alerts
SQL[INSERT IGNORE INTO perf_times
(type
,doing
,start
,duration
,devices
,poller
) VALUES (:type,:doing,:start,:duration,:devices,:poller) {“type”:“poll”,“doing”:“192.168.13.100”,“start”:1588082729.761592,“duration”:“1.474”,“devices”:1,“poller”:null} 0.53ms]
./poller.php 192.168.13.100 2020-04-28 16:05:31 - 1 devices polled in 1.474 secs
SNMP [4/0.06s]: Get[3/0.05s] Getnext[0/0.00s] Walk[1/0.01s]
MySQL [10/0.01s]: Cell[1/0.00s] Row[-1/-0.00s] Rows[5/0.01s] Column[0/0.00s] Update[3/0.01s] Insert[2/0.00s] Delete[0/0.00s]
InfluxDB [6/0.05s]: Write[6/0.05s]
RRD [6/0.00s]: Update[6/0.00s]
