Hi all our install recently added a powered by librenms which is great and we’re glad you did it - but the layer has a lot of unused horizontal whitespace. Has anyone considered making the horizontal size of the layer match the amount of text it contains? Our dashboards are exactly formatted so we’re not seeing a small portion of the bottom widgets.
also if anyone knows if config.php has configuration options for the powered by bit we would like to see whats available.
cheers!
