Is there any to prevent Librenms from discovering a certain interface by name?
Basically, I don’t want to keep going into port settings for a device in Libre and toggle the disable polling. I don’t want it to be discovered in the first place.
This is what I used on my installation to stop seeing all the interfaces that Ubiquiti creates every time the radios reconnect.
Add to config.php
### Ignore bad ports
$config[‘bad_if’][] = “ath1”;
Configuration Docs - LibreNMS Docs - Interfaces to be ignored
Thanks for the link! I will have to try this out. Looks like you can do regex.
I will give it a shot.
