I install librenms on Debian 11 and Apacha default configuration. Works OK.
I need to transfer my system to another machine with Debian 11. I made a new instance, unfortunately I have a problem with html.
On the old server, librenms was available as 192.168.1.10/
It must be on the new one 192.168.1.20/librenms/ , I come to the problems where I list directories 192.168.1.20/librenms/, if I click on the directory html, takes me to the site 192.168.1.20/librenms/html/install, and displays the page to me 404 Not Found.
If it can’t be the root directory of the web server due to some other web service being installed there, add a hostname entry for librenms specifically in DNS and configure a virtual domain in the web server for librenms using that hostname, then it can be the root web directory. (But you will only be able to access it via hostname, which might or might not be OK for your situation)
[OK] Composer Version: 2.2.2
[WARN] You have no devices.
Consider adding a device such as localhost: /addhost
[WARN] Your install is over 24 hours out of date, last update: Mon, 27 Dec 2021 23:32:50 +0000
librenms@mnplstwdeb03:~$
