Voltage
Once the update finishes, this sensor, which works without problems, but creates an alert for 234000 volts, triggering messages according to the internal rules.
Power
Once the update is finished, this sensor appears, and it delivers a value equal to 0. Something i configure wrong?
I’m update my install and rerun discovery. Doesn’t solve the issue. I erase the server and load again, and it fix the Fan Sensor problem, but lost the recopilated data.
The voltaje at 234000V alert problem remains, and power sensor remains in “0W”.-
Here is the snmpwalk, the problem is not de OID itself, it is the index declared in the discovery function. The last number of the OID its repetead in the index.
