Since the update this weekend, we are unable to see the alert rule page and the alert transport page. Is there anybody who has a solution for this?
Thank you in advance.
Best regards,
Remon Willems
I have exactly the same problem with the last version of LibreNMS 23.5.0-8-g713bef33b.
Could someone help us?
thanks so much
Best regards
Samuel
I also have this same problem trying to view the Alert Rules and Alert Transport pages. Other pages all seem to work fine.
This shows up in librenms.log when I open either of those:
Declaration of LibreNMS\Alert\Transport\Execute::deliverAlert($obj, $opts) must be compatible with LibreNMS\Interfaces\Alert\Transport::deliverAlert(array $alert_data): bool {“userId”:5,“exception”:“[object] (Symfony\Component\ErrorHandler\Error\FatalError(code: 0): Declaration of LibreNMS\Alert\Transport\Execute::deliverAlert($obj, $opts) must be compatible with LibreNMS\Interfaces\Alert\Transport::deliverAlert(array $alert_data): bool at /opt/librenms/LibreNMS/Alert/Transport/Execute.php:32)”}
I am up to date, validate.php and daily.sh run successfully:
./daily.sh
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
Caching Mac OUI data OK
| LibreNMS | 23.5.0-15-gb14e2d460 (2023-06-13T06:35:00-05:00) |
| DB Schema | 2023_04_27_164904_update_slas_opstatus_tinyint (252) |
| PHP | 8.1.2-1ubuntu2.11 |
| Python | 3.10.6 |
| Database | MariaDB 10.6.12-MariaDB-0ubuntu0.22.04.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.1 |
[OK] Composer Version: 2.5.7
[OK] MySQl and PHP time match
[WARN] Using database for locking, you should set CACHE_DRIVER=redis
Didn’t have the time to go further but your post gave me an idea. Probably you have a custom transport method named Execute.php (located in the opt/librenms/LibreNMS/Alert/Transport/ folder). Try to rename the file from Execute.php to Execute.txt and check if the pages are loading.
Ah yes thank you! I had the Execute.php transport script and it looks like it needs new syntax for the deliverAlert function. I moved the file out for now and everything is fine, I’ll just have to find a workaround for alerts that used this
