Is it possible to push recover messages form alerts? We have a custom transport rule that notifies a case management system through posting to a form when an alert is created. When a recovery alert is generated, it tells the case management system that the device is up and running again. If there’s a communication failure between LibreNMS and the case management system, devices that are in alert will never be seen as up and running again and we have to manually delete alerting devices from the database table in the case management system.
Is there a way to resend the recover alert? Right now we have a major problem after a system failure last night when practically all devices went into alert and then there was a communication failure with errors in LibreNMS for the recovery alert. We now have thousands of devices in alert in the case management system but they are all recovered in LibreNMS.
