When a device being added to LibreNMS server
- Is it configurable to customize what to monitor and what not? E.g., may I filter out some interfaces that are shutdown?
- Is it configurable to attach user MIBs to a device?
- May I define different level of threshold for a check? E.g., minor alarm on CPU util > 80 %, and major alarm on CPU util > 95%?
- May I define different thresholds for different groups of devices?
Thanks and regards.
Yes - under settings - port settings.
No, LibreNMS is not MIB based monitoring.
Yes see docs about alerting. Home - LibreNMS Docs
You could probably do that with alert rules and set up rule mapping to device groups. Again see the docs.
Thanks very much Kevin!
I am new to the tool and was wondering how the metrics to be monitored are configured for a device.
As per your reply, it is configurable on what to monitor and what not. Is it configurable per device, per group of devices? where can I find the configurations?
LibreNMS is not MIB based, how the metrics are defined?
Thanks and regards.
This all coded per device OS definitions into yaml file.
https://docs.librenms.org/#Developing/Support-New-OS/
Also if you want to check out the demo
https://demo.librenms.org
