So I am trying to configure radius in which the users are admins. I can authenticate, but the new users don’t have admin access, or at least not able to see devices, users permissions/device access says “No access!” and I have no devices in my devices pull down. Running using mysql, I can add users as admin and
they have global access.
I have set the level in config.php:
$config[‘radius’][‘default_level’] = 10;
It doesn’t seem to matter if the user’s account exists locally or if I delete the account and have librenms create it, the result is the same, the account can login but the perms are wrong. Am I running the wrong version? I think I went through the exact U18 install (
I am running U18 apache, here is validate.php:
root@librenms : /opt/librenms # ./validate.php
LibreNMS | 1.44-40-geeca2ab3c
DB Schema | 269
PHP | 7.2.10-0ubuntu0.18.04.1
MySQL | 10.1.34-MariaDB-0ubuntu0.18.04.1
RRDTool | 1.7.0
SNMP | NET-SNMP 5.7.3
