New to LibreNMS and SNMP here
I’m trying to monitor custom OpenWrt devices and I’d like to see the result of a command (giving if an wan interface is up or down) directly in the device Overview tab of the device. I managed to get the result of the command via snmpwalk but I can’t add it in the custom OID section as this is a String and as far as I know you can’t make a gauge or a counter of a String.
Btw, thanks for the good work, everything working properly.
The result of the command can be found here
Regards
