Ricoh mp c3300 there is four toners librenms shows five toners
LibreNMS 0e6b42fc05e5b936e2f9fa36745234c8a09d7633
DB Schema 185
PHP 7.0.15-0ubuntu0.16.04.4
MySQL 10.0.29-MariaDB-0ubuntu0.16.04.1
RRDTool 1.5.5
SNMP NET-SNMP 5.7.3
.1.3.6.1.4.1.367.3.2.1.2.24.1.1.2.1 = STRING: “Black Toner”
.1.3.6.1.4.1.367.3.2.1.2.24.1.1.2.2 = STRING: “Cyan Toner”
.1.3.6.1.4.1.367.3.2.1.2.24.1.1.2.3 = STRING: “Magenta Toner”
.1.3.6.1.4.1.367.3.2.1.2.24.1.1.2.4 = STRING: “Yellow Toner”
.1.3.6.1.4.1.367.3.2.1.2.24.1.1.3.1 = STRING: “Black Toner”
.1.3.6.1.4.1.367.3.2.1.2.24.1.1.3.2 = STRING: “Cyan Toner”
.1.3.6.1.4.1.367.3.2.1.2.24.1.1.3.3 = STRING: “Magenta Toner”
.1.3.6.1.4.1.367.3.2.1.2.24.1.1.3.4 = STRING: “Yellow Toner”
.1.3.6.1.4.1.367.3.2.1.2.24.1.1.4.1 = INTEGER: 13
.1.3.6.1.4.1.367.3.2.1.2.24.1.1.4.2 = INTEGER: 10
.1.3.6.1.4.1.367.3.2.1.2.24.1.1.4.3 = INTEGER: 11
.1.3.6.1.4.1.367.3.2.1.2.24.1.1.4.4 = INTEGER: 12
.1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.1 = INTEGER: 90
.1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.2 = INTEGER: 90
.1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.3 = INTEGER: 90
.1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.4 = INTEGER: 100
Please post the output of:
./discovery.php -h HOSTNAME -d -m toner
./poller.php -h HOSTNAME -d -m toner -r -f
LibreNMS Discovery
Version info:
Commit SHA: 0e6b42fc05e5b936e2f9fa36745234c8a09d7633
DB Schema: 185
PHP: 7.0.15-0ubuntu0.16.04.4
MySQL: 10.0.29-MariaDB-0ubuntu0.16.04.1
RRDTool: 1.5.5
SNMP: NET-SNMP 5.7.3
DEBUG!
SQL[SELECT version FROM dbSchema ORDER BY version DESC LIMIT 1]
DB Schema already up to date.
SQL[SELECT * FROM devices WHERE status = 1 AND disabled = 0 AND hostname LIKE ‘192.168.122.199’ ORDER BY device_id DESC]
SQL[SELECT * FROM devices_attribs WHERE device_id = ‘50’]
192.168.122.199 50 ricoh SQL[INSERT INTO device_perf (xmt,rcv,loss,min,max,avg,device_id,timestamp) VALUES (‘3’,‘3’,‘0’,‘0.44’,‘0.50’,‘0.47’,‘50’,NOW())]
SNMP Check response code: 0
Modules status: Global+ OS+ Device
Load disco module toner
Toner: SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m Printer-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 prtMarkerColorantMarkerIndex]
prtMarkerColorantMarkerIndex.1.1 = 1
prtMarkerColorantMarkerIndex.1.2 = 1
prtMarkerColorantMarkerIndex.1.3 = 1
prtMarkerColorantMarkerIndex.1.4 = 1
prtMarkerColorantMarkerIndex.1.5 = 1
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m Printer-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 prtMarkerSuppliesLevel]
prtMarkerSuppliesLevel.1.1 = -3
prtMarkerSuppliesLevel.1.2 = -3
prtMarkerSuppliesLevel.1.3 = -3
prtMarkerSuppliesLevel.1.4 = -3
prtMarkerSuppliesLevel.1.5 = -3
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m Printer-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 prtMarkerSuppliesMaxCapacity]
prtMarkerSuppliesMaxCapacity.1.1 = -2
prtMarkerSuppliesMaxCapacity.1.2 = -2
prtMarkerSuppliesMaxCapacity.1.3 = -2
prtMarkerSuppliesMaxCapacity.1.4 = -2
prtMarkerSuppliesMaxCapacity.1.5 = -2
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUsa -m Printer-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 prtMarkerSuppliesDescription]
prtMarkerSuppliesDescription.1.1 = "Black Toner"
prtMarkerSuppliesDescription.1.2 = "Waste Toner"
prtMarkerSuppliesDescription.1.3 = "Cyan Toner"
prtMarkerSuppliesDescription.1.4 = "Magenta Toner"
prtMarkerSuppliesDescription.1.5 = “Yellow Toner”
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUsa -m Printer-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 prtMarkerColorantValue]
prtMarkerColorantValue.1.1 = "black"
prtMarkerColorantValue.1.2 = "other"
prtMarkerColorantValue.1.3 = "cyan"
prtMarkerColorantValue.1.4 = "magenta"
prtMarkerColorantValue.1.5 = “yellow”
Discover Toner: .1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.1, 1, jetdirect, Black, , 100, 50
SQL[SELECT COUNT(toner_id) FROM toner WHERE device_id = ‘50’ AND toner_type = ‘jetdirect’ AND toner_index = ‘1’ AND toner_oid =’.1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.1’]
SQL[SELECT * FROM toner WHERE device_id = ‘50’ AND toner_type = ‘jetdirect’ AND toner_index =‘1’]
.Discover Toner: .1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.2, 2, jetdirect, Other, , 100, 50
SQL[SELECT COUNT(toner_id) FROM toner WHERE device_id = ‘50’ AND toner_type = ‘jetdirect’ AND toner_index = ‘2’ AND toner_oid =’.1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.2’]
SQL[SELECT * FROM toner WHERE device_id = ‘50’ AND toner_type = ‘jetdirect’ AND toner_index =‘2’]
.Discover Toner: .1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.3, 3, jetdirect, Cyan, , 100, 50
SQL[SELECT COUNT(toner_id) FROM toner WHERE device_id = ‘50’ AND toner_type = ‘jetdirect’ AND toner_index = ‘3’ AND toner_oid =’.1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.3’]
SQL[SELECT * FROM toner WHERE device_id = ‘50’ AND toner_type = ‘jetdirect’ AND toner_index =‘3’]
.Discover Toner: .1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.4, 4, jetdirect, Magenta, , 100, 50
SQL[SELECT COUNT(toner_id) FROM toner WHERE device_id = ‘50’ AND toner_type = ‘jetdirect’ AND toner_index = ‘4’ AND toner_oid =’.1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.4’]
SQL[SELECT * FROM toner WHERE device_id = ‘50’ AND toner_type = ‘jetdirect’ AND toner_index =‘4’]
.Discover Toner: .1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.5, 5, jetdirect, Yellow, , 100, 50
SQL[SELECT COUNT(toner_id) FROM toner WHERE device_id = ‘50’ AND toner_type = ‘jetdirect’ AND toner_index = ‘5’ AND toner_oid =’.1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.5’]
SQL[SELECT * FROM toner WHERE device_id = ‘50’ AND toner_type = ‘jetdirect’ AND toner_index =‘5’]
Checking valid toner …
Array
[jetdirect] => Array
[.1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.1] => 1
[.1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.2] => 1
[.1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.3] => 1
[.1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.4] => 1
[.1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.5] => 1
SQL[SELECT * FROM toner WHERE device_id = ‘50’]
Array
[0] => Array
[toner_id] => 116
[device_id] => 50
[toner_index] => 1
[toner_type] => jetdirect
[toner_oid] => .1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.1
[toner_descr] => Black
[toner_capacity] => 100
[toner_current] => 90
[toner_capacity_oid] =>
[1] => Array
        [toner_id] => 117
        [device_id] => 50
        [toner_index] => 2
        [toner_oid] => .1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.2
        [toner_descr] => Other
[2] => Array
        [toner_id] => 118
        [device_id] => 50
        [toner_index] => 3
        [toner_oid] => .1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.3
        [toner_descr] => Cyan
[3] => Array
        [toner_id] => 119
        [device_id] => 50
        [toner_index] => 4
        [toner_oid] => .1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.4
        [toner_descr] => Magenta
        [toner_current] => 100
[4] => Array
        [toner_id] => 120
        [device_id] => 50
        [toner_index] => 5
        [toner_oid] => .1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.5
        [toner_descr] => Yellow
        [toner_current] => 0
Runtime for discovery module ‘toner’: 0.0710 seconds with 16480 bytes
Unload disco module toner
SQL[SELECT attrib_value FROM devices_attribs WHERE device_id = ‘50’ AND attrib_type = ‘poll_mib’ ]
MIB: registering
SNMP[snmptranslate -M /opt/librenms/mibs -IR -m all enterprises.367.1.1 2>/dev/null]
RFC1155-SMI::enterprises.367.1.1
SNMP translated: all::enterprises.367.1.1 -> RFC1155-SMI::enterprises.367.1.1
Array
MIB: Could not load definition for RFC1155-SMI::enterprises.367.1.1
SQL[UPDATE devices set last_discovered =NOW(),last_discovered_timetaken =‘0.958’ WHERE device_id = ‘50’]
Discovered in 0.958 seconds
SQL[INSERT INTO perf_times (type,doing,start,duration,devices,poller) VALUES (‘discover’,‘192.168.122.199’,‘1492600541.5023’,‘1.007’,‘1’,‘haralampije-To-be-filled-by-O-E-M\n’)]
./discovery.php 192.168.122.199 2017-04-19 13:15:42 - 1 devices discovered in 1.007 secs
SNMP: Get[1/0.02s] Walk [5/0.07s]
MySQL: Cell[8/0.00s] Row[7/0.00s] Rows[5/0.00s] Column[0/0.00s] Update[1/0.03s] Insert[2/0.06s] Delete[0/0.00s]
LibreNMS Poller
Version info:
Commit Date: 1492594930
DB Schema: 185
RRDTool: 1.5.5
DEBUG!
Starting polling run:
SQL[SELECT * FROM devices WHERE disabled = 0 AND hostname = ‘192.168.122.199’ ORDER BY device_id ASC]
Hostname: 192.168.122.199
Device ID: 50
OS: ricoh (printer)
SQL[INSERT INTO device_perf (xmt,rcv,loss,min,max,avg,device_id,timestamp) VALUES (‘3’,‘3’,‘0’,‘0.30’,‘0.56’,‘0.46’,‘50’,NOW())]
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OQnUst -m SNMPv2-MIB:HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 sysUpTime.0 sysLocation.0 sysContact.0 sysName.0 sysObjectID.0]
sysUpTime.0 = 2179400
sysLocation.0 =
sysContact.0 =
sysName.0 = Aficio MP C3300
sysObjectID.0 = enterprises.367.1.1
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OvQ -m SNMPv2-MIB:HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 sysDescr.0]
RICOH Aficio MP C3300 1.24 / RICOH Network Printer C model / RICOH Network Scanner C model
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OQnUst -m HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 snmpEngineTime.0 hrSystemUptime.0]
snmpEngineTime.0 = No Such Object available on this agent at this OID
hrSystemUptime.0 = 2179400
Using hrSystemUptime (21794s)
RRD[update /opt/librenms/rrd/192.168.122.199/uptime.rrd N:21794]
[RRD Disabled]Uptime: 6h 3m 14s
Load poller module toner
Checking toner Black… SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OUqnv -M /opt/librenms/mibs udp:HOSTNAME:161 .1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.1]
90
90 %
RRD[update /opt/librenms/rrd/192.168.122.199/toner-1.rrd N:90]
[RRD Disabled]SQL[UPDATE toner set toner_current =‘90’,toner_capacity =‘100’ WHERE toner_id = ‘116’]
Checking toner Other… SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OUqnv -M /opt/librenms/mibs udp:HOSTNAME:161 .1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.2]
90
90 %
RRD[update /opt/librenms/rrd/192.168.122.199/toner-2.rrd N:90]
[RRD Disabled]SQL[UPDATE toner set toner_current =‘90’,toner_capacity =‘100’ WHERE toner_id = ‘117’]
Checking toner Cyan… SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OUqnv -M /opt/librenms/mibs udp:HOSTNAME:161 .1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.3]
90
90 %
RRD[update /opt/librenms/rrd/192.168.122.199/toner-3.rrd N:90]
[RRD Disabled]SQL[UPDATE toner set toner_current =‘90’,toner_capacity =‘100’ WHERE toner_id = ‘118’]
Checking toner Magenta… SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OUqnv -M /opt/librenms/mibs udp:HOSTNAME:161 .1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.4]
100
100 %
RRD[update /opt/librenms/rrd/192.168.122.199/toner-4.rrd N:100]
[RRD Disabled]SQL[UPDATE toner set toner_current =‘100’,toner_capacity =‘100’ WHERE toner_id = ‘119’]
Checking toner Yellow… SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OUqnv -M /opt/librenms/mibs udp:HOSTNAME:161 .1.3.6.1.4.1.367.3.2.1.2.24.1.1.5.5]
No Such Instance currently exists at this OID
0 %
RRD[update /opt/librenms/rrd/192.168.122.199/toner-5.rrd N:0]
[RRD Disabled]SQL[UPDATE toner set toner_current =‘0’,toner_capacity =‘100’ WHERE toner_id = ‘120’]
Runtime for poller module ‘toner’: 0.2784 seconds with 10208 bytes
Unload poller module toner
RRD[update /opt/librenms/rrd/192.168.122.199/poller-perf-toner.rrd N:0.27841091156006]
[RRD Disabled]### Start Device Groups ###
SQL[SELECT * FROM device_groups ORDER BY name]
SQL[SELECT DISTINCT(devices.device_id) FROM devices WHERE devices.device_id=‘50’ AND (devices.mac = “” && devices.ip = “” ) LIMIT 1]
SQL[SELECT device_group_id FROM device_group_device WHERE device_id=‘50’]
Groups Added:
Groups Removed:
End Device Groups
RRD[update /opt/librenms/rrd/192.168.122.199/poller-perf.rrd N:0.768]
[RRD Disabled]RRD[update /opt/librenms/rrd/192.168.122.199/ping-perf.rrd N:0.46]
[RRD Disabled]Polled in 0.768 seconds
Updating 192.168.122.199
SQL[UPDATE devices set uptime =‘21794’,last_ping =NOW(),last_ping_timetaken =‘0.46’,last_polled =NOW(),last_polled_timetaken =‘0.768’ WHERE device_id = ‘50’]
UPDATED!
Start Alerts
SQL[SELECT alert_schedule.schedule_id FROM alert_schedule LEFT JOIN alert_schedule_items ON alert_schedule.schedule_id=alert_schedule_items.schedule_id WHERE ( alert_schedule_items.target = ‘50’ ) && ((alert_schedule.recurring = 0 AND (NOW() BETWEEN alert_schedule.start AND alert_schedule.end)) OR (alert_schedule.recurring = 1 AND (alert_schedule.start_recurring_dt <= date_format(NOW(), ‘–%d’) AND (end_recurring_dt >= date_format(NOW(), ‘–%d’) OR end_recurring_dt is NULL OR end_recurring_dt = ‘0000-00-00’ OR end_recurring_dt = ‘’)) AND (date_format(now(), ‘%H:%i:%s’) BETWEEN start_recurring_hr AND end_recurring_hr) AND (recurring_day LIKE CONCAT(’%’,date_format(now(), ‘’),’%’) OR recurring_day is null or recurring_day = ‘’))) LIMIT 1]
SQL[SELECT alert_rules.* FROM alert_rules LEFT JOIN alert_map ON alert_rules.id=alert_map.rule WHERE alert_rules.disabled = 0 && ( (alert_rules.device_id = -1 || alert_rules.device_id = ‘50’ ) || alert_map.target = ‘50’ )]
Rule #1 (Devices up/down):
SQL[SELECT state FROM alerts WHERE rule_id = ‘1’ && device_id = ‘50’ ORDER BY id DESC LIMIT 1]
SQL[SELECT * FROM devices WHERE (devices.device_id = ‘50’) && ( ( ( devices.status = 0 && ( ( devices.disabled = 0 && devices.ignore = 0 ) ) ) ) = “1”)]
Status: NOCHG
Rule #2 (Device rebooted):
SQL[SELECT state FROM alerts WHERE rule_id = ‘2’ && device_id = ‘50’ ORDER BY id DESC LIMIT 1]
SQL[SELECT * FROM devices WHERE (devices.device_id = ‘50’) && (devices.uptime < “300” && ( ( devices.disabled = 0 && devices.ignore = 0 ) ) = “1”)]
Status: NOCHG
Rule #3 (BGP Session down):
SQL[SELECT state FROM alerts WHERE rule_id = ‘3’ && device_id = ‘50’ ORDER BY id DESC LIMIT 1]
SQL[SELECT * FROM bgpPeers,devices WHERE (( devices.device_id = bgpPeers.device_id ) && bgpPeers.device_id = ‘50’) && (bgpPeers.bgpPeerState != “established” && ( ( devices.status = 1 && ( ( devices.disabled = 0 && devices.ignore = 0 ) ) ) ) = “1”)]
Status: NOCHG
Rule #4 (BGP Session established):
SQL[SELECT state FROM alerts WHERE rule_id = ‘4’ && device_id = ‘50’ ORDER BY id DESC LIMIT 1]
SQL[SELECT * FROM bgpPeers WHERE (bgpPeers.device_id = ‘50’) && (bgpPeers.bgpPeerFsmEstablishedTime < “300” && bgpPeers.bgpPeerState = “established”)]
Status: NOCHG
Rule #5 (Port status up/down):
SQL[SELECT state FROM alerts WHERE rule_id = ‘5’ && device_id = ‘50’ ORDER BY id DESC LIMIT 1]
SQL[SELECT * FROM ports WHERE (ports.device_id = ‘50’) && ( ( ( ports.ifOperStatus = “down” && ports.ifAdminStatus != “down” && ( ( ports.deleted = 0 && ports.ignore = 0 && ports.disabled = 0 ) ) ) ) = “1”)]
Status: NOCHG
Rule #6 (Port utilisation over threshold):
SQL[SELECT state FROM alerts WHERE rule_id = ‘6’ && device_id = ‘50’ ORDER BY id DESC LIMIT 1]
SQL[SELECT * FROM ports WHERE (ports.device_id = ‘50’) && ( ( ( ( ports.ifInOctets_rate*8 ) / ports.ifSpeed ) *100 ) >= “80” && ( ( ports.ifOperStatus = “up” && ports.ifAdminStatus = “up” && ( ( ports.deleted = 0 && ports.ignore = 0 && ports.disabled = 0 ) ) ) ) = “1” && ( ( ports.deleted = 0 && ports.ignore = 0 && ports.disabled = 0 ) ) = “1”)]
Status: NOCHG
Rule #7 (Sensor over limit):
SQL[SELECT state FROM alerts WHERE rule_id = ‘7’ && device_id = ‘50’ ORDER BY id DESC LIMIT 1]
SQL[SELECT * FROM sensors WHERE (sensors.device_id = ‘50’) && (sensors.sensor_current > sensors.sensor_limit && sensors.sensor_alert = “1”)]
Status: NOCHG
Rule #8 (Sensor under limit):
SQL[SELECT state FROM alerts WHERE rule_id = ‘8’ && device_id = ‘50’ ORDER BY id DESC LIMIT 1]
SQL[SELECT * FROM sensors WHERE (sensors.device_id = ‘50’) && (sensors.sensor_current < sensors.sensor_limit_low && sensors.sensor_alert = “1”)]
Status: NOCHG
Rule #9 (Service up/down):
SQL[SELECT state FROM alerts WHERE rule_id = ‘9’ && device_id = ‘50’ ORDER BY id DESC LIMIT 1]
SQL[SELECT * FROM services WHERE (services.device_id = ‘50’) && (services.service_status != “0”)]
Status: NOCHGSQL[SELECT alert_log.id, alert_log.details FROM alert_log,alert_rules WHERE alert_log.rule_id = alert_rules.id && alert_log.device_id = ‘50’ && alert_log.rule_id = ‘9’ && alert_rules.disabled = 0 ORDER BY alert_log.id DESC LIMIT 1]
SQL[UPDATE alert_log set details =‘xڍP�� ��gCJ+(��ŋ�\0c
R�$}�.51M��Ńr�����.3����r(�T�aY�8���
hǧ3��j"9����Zd|>*Tθ�1�ӭTB��’G��� Z[4�2�\n&��ė�RE����Qw]�c
JGà�DeB������~�ڨ\(��mBwQ7��4���W��qwG-��������u
�X.��Z��2��,�/ofKp�’ WHERE id = ‘2545’]
End Alerts
SQL[INSERT INTO perf_times (type,doing,start,duration,devices,poller) VALUES (‘poll’,‘192.168.122.199’,‘1492600616.4601’,‘0.921’,‘1’,‘haralampije-To-be-filled-by-O-E-M\n’)]
./poller.php 192.168.122.199 2017-04-19 13:16:57 - 1 devices polled in 0.921 secs
SNMP: Get[9/0.15s] Walk [0/0.00s]
MySQL: Cell[4/0.00s] Row[9/-0.00s] Rows[16/0.00s] Column[3/0.00s] Update[7/0.30s] Insert[2/0.06s] Delete[0/0.00s]
So it reports a waste toner which we in turn report back.
That is new for me, now I understand. However capacity is not right, it shows yelow at 0%, and as you can see on last picture it is at 81%.
Looks like it might be a device issue, you seem to get varying OIDs in the results. Please provide the full output of snmpbulkwalk -OUneb -v2c -c COMMUNITY HOSTNAME .
Ensure it contains data from .1.3.6.1.4.1.367.3.2.1.2.24.1
Sorry for my late reply, I think you need to know that I could not get correct toner levels everything was always sitting at 50%. So I changed OIDs in toner.inc.php to
probably my fault, but at least toner levels are now moving
I can’t see what you’ve changed from the screenshot, please provide a diff.
The snmpwalk doesn’t contain the output from .1.3.6.1.4.1.367.3.2.1.2.24.1 so you will need to run it with that instead of . - please pastebin the results (or | ./pbin.sh) from your install.
That waste toner confused me because it is not shown in device system information nor on web interface of device. And what is more interesting is that web interface shows different results from device it self.
I am certain that web interface is showing correct values according to service guy. Anyways big thanks for helping me sort this out.
snmpbulkwalk https://p.libren.ms/view/6b099283
waste toner is not shown in snmpbulkwalk -OUneb -v2c -c COMMUNITY HOSTNAME .1.3.6.1.4.1.367.3.2.1.2.24.1
I think waste toner should be shown last after yelow toner or not at all because then i will get correct toner levels
toner.inc.php https://p.libren.ms/view/9ed6f0c3 I edited lines 26 and 27
