Hi
Current Setup:
- 3x Poller servers, 1x RRDcached server and 1x DB server for LibreNMS.
- 1x Netflow Server
-bash-4.2$ ./validate.php
Component | Version |
LibreNMS | 1.53.1-42-gc0c3ad2 |
DB Schema | 2019_05_30_225937_device_groups_rewrite (135) |
PHP | 7.2.19 |
MySQL | 5.5.60-MariaDB |
RRDTool | 1.7.1 |
SNMP | NET-SNMP 5.7.2 |
- Integrated Netflow server to LibreNMS config as per documentation
- An NFS share is currently mounted on the 3x Poller servers that point to the Netflow data (nfsen_rrds and nfsen-base folder); Permissions for this is functioning as expected
Receive the below output when generating Netflow Graphs on LibreNMS:
“ERROR: absolute path names not allowed when talking to a remote daemon”
Note that graphs are generating correctly for SNMP device RRD files (as it uses relative addressing).
Attached the RRD command below for reference.
RRD Command for SNMP device (relative path generating graphs correctly):
rrdtool graph /tmp/CUkiebrF4tl5zkvF -l 0 -E --start 1575411000 --end 1575497400 --width 1728 --height 504 -c BACK#EEEEEE00 -c SHADEA#EEEEEE00 -c SHADEB#EEEEEE00 -c CANVAS#FFFFFF00 -c GRID#a5a5a5 -c MGRID#FF9999 -c FRAME#5e5e5e -c ARROW#5e5e5e -R normal -c FONT#000000 --font LEGEND:8:DejaVuSansMono --font AXIS:7:DejaVuSansMono --font-render-mode normal DEF:connections=10.0.0.250/asa_conns.rrd:connections:AVERAGE DEF:connections_max=10.0.0.250/asa_conns.rrd:connections:MAX DEF:connections_min=10.0.0.250/asa_conns.rrd:connections:MIN AREA:connections_min LINE1.5:connections#cc0000:'Current connections ’ GPRINT:connections_min:MIN:%4.0lf GPRINT:connections:LAST:%4.0lf GPRINT:connections_max:MAX:%4.0lf\l --daemon nms-rrdcached.localdomain.local:42217
RRD Command for Netflow device (uses absolute path causing graphs to not generate):
rrdtool graph /tmp/l3R9JuqxKK8WjfBf -l 0 -E --start 1575409800 --end 1575412200 --width 1728 --height 504 -c BACK#EEEEEE00 -c SHADEA#EEEEEE00 -c SHADEB#EEEEEE00 -c CANVAS#FFFFFF00 -c GRID#a5a5a5 -c MGRID#FF9999 -c FRAME#5e5e5e -c ARROW#5e5e5e -R normal -c FONT#000000 --font LEGEND:8:DejaVuSansMono --font AXIS:7:DejaVuSansMono --font-render-mode normal COMMENT:‘Flows/s Now Min Max Avg\l’ DEF:flows_tcp1=/u01/nfsen/nfsen-1.3.6p1/profiles-stat/librenms/10.255.255.3.rrd:flows_tcp:AVERAGE CDEF:flows_tcp1min=flows_tcp1 CDEF:flows_tcp1max=flows_tcp1 AREA:flows_tcp1#A0A0E5:‘tcp ‘:STACK GPRINT:flows_tcp1:LAST:%5.2lf%s GPRINT:flows_tcp1min:MIN:%5.2lf%s GPRINT:flows_tcp1max:MAX:%5.2lf%s GPRINT:flows_tcp1:AVERAGE:’%5.2lf%s\n’ COMMENT:’\n’ DEF:flows_udp2=/u01/nfsen/nfsen-1.3.6p1/profiles-stat/librenms/10.255.255.3.rrd:flows_udp:AVERAGE CDEF:flows_udp2min=flows_udp2 CDEF:flows_udp2max=flows_udp2 AREA:flows_udp2#8080BD:‘udp ‘:STACK GPRINT:flows_udp2:LAST:%5.2lf%s GPRINT:flows_udp2min:MIN:%5.2lf%s GPRINT:flows_udp2max:MAX:%5.2lf%s GPRINT:flows_udp2:AVERAGE:’%5.2lf%s\n’ COMMENT:’\n’ DEF:flows_icmp3=/u01/nfsen/nfsen-1.3.6p1/profiles-stat/librenms/10.255.255.3.rrd:flows_icmp:AVERAGE CDEF:flows_icmp3min=flows_icmp3 CDEF:flows_icmp3max=flows_icmp3 AREA:flows_icmp3#606096:‘icmp ‘:STACK GPRINT:flows_icmp3:LAST:%5.2lf%s GPRINT:flows_icmp3min:MIN:%5.2lf%s GPRINT:flows_icmp3max:MAX:%5.2lf%s GPRINT:flows_icmp3:AVERAGE:’%5.2lf%s\n’ COMMENT:’\n’ DEF:flows_other4=/u01/nfsen/nfsen-1.3.6p1/profiles-stat/librenms/10.255.255.3.rrd:flows_other:AVERAGE CDEF:flows_other4min=flows_other4 CDEF:flows_other4max=flows_other4 AREA:flows_other4#40406F:‘other ‘:STACK GPRINT:flows_other4:LAST:%5.2lf%s GPRINT:flows_other4min:MIN:%5.2lf%s GPRINT:flows_other4max:MAX:%5.2lf%s GPRINT:flows_other4:AVERAGE:’%5.2lf%s\n’ COMMENT:’\n’ --daemon nms-rrdcached.localdomain.local:42217
/opt/librenms/config.php
$config[‘nfsen_enable’] = 1;
$config[‘nfsen_rrds’][] = ‘/u01/nfsen/nfsen-1.3.6p1/profiles-stat/librenms/’;
$config[‘nfsen_base’][] = ‘/u01/nfsen/nfsen-1.3.6p1/’;
Please advise how to resolve this as the RRD commands inserting the location of the RRD files are generated by the WebUI.
