One of my Cisco switches is having an issue where every sensor on Eth1/5 deletes and re-adds itself, resetting all of the values and constantly alerting. It happens every 2-5 days. This is the only devices that does it and I can’t find a pattern or reason why. The SNMP config is identical to the other 20+ cisco devices we have added yet this is the only one that does it.
It is a Cisco N3K-C3064PQ-10GE running NX-OS 7.0(3)I7(6). Since I’ve posted this I’ve discovered that Ether1/9 is also doing it, but none of the other ports. Here are the configs on both ports:
Prodding at random things to help eliminate possibilities … are all the ports BiDi SFPs or only those two, and are they genuine or otherwise fully visible/acknowledged from the device CLI with valid idprom data?
