Found possible bug on Dynamic Discovery
Or I not fully understand the logic behind sensor limits.
it seems that snmp sensor limits are not written into database.
instead the calculated values are going into db.
I the example from the sensor sfpDiagRxPower below, the “sensor_limit” got from snmp should be -3 (warn_limit) or -5 (high_limit)
But instead a calculated value of -17.8505 is going int Database.
–snip–
Dbm: Dynamic Discovery (dbm): Array
[data] => Array
[0] => Array
[oid] => sfpDiagTable
[value] => sfpDiagRxPower
[num_oid] => .1.3.6.1.4.1.637.61.1.56.5.1.7.
[descr] => SFP {{ $index }} RX Power
[index] => sfpDiagRxPower.{{ $index }}
[low_limit] => sfpDiagRSSIRxPowerAlmLow
[low_warn_limit] => sfpDiagRSSIRxPowerWarnLow
[warn_limit] => sfpDiagRSSIRxPowerWarnHigh
[high_limit] => sfpDiagRSSIRxPowerAlmHigh
[1] => Array
[value] => sfpDiagTxPower
[num_oid] => .1.3.6.1.4.1.637.61.1.56.5.1.6.
[descr] => SFP {{ $index }} TX Power
[index] => sfpDiagTxPower.{{ $index }}
[low_limit] => sfpDiagRSSITxPowerAlmLow
[low_warn_limit] => sfpDiagRSSITxPowerWarnLow
[warn_limit] => sfpDiagRSSITxPowerWarnHigh
[high_limit] => sfpDiagRSSITxPowerAlmHigh
Data sfpDiagTable: Array
[4353.257] => Array
[sfpDiagLogicalSlot] => 4353
[sfpDiagSfpFaceplateNumber] => 257
[sfpDiagAvailable] => 1
[sfpDiagLOS] => 2
[sfpDiagTxFault] => 2
[sfpDiagTxPower] => -5.90 dBm
[sfpDiagRxPower] => -18.79 dBm
[sfpDiagTxBiasCurrent] => 7.28 mA
[sfpDiagSupplyVoltage] => 3.29 VDC
[sfpDiagTemperature] => 30.97 degrees Celsius
[sfpDiagTCAStatusTemperature] => 2
[sfpDiagTCAStatusVoltage] => 2
[sfpDiagTCAStatusBiasCurrent] => 2
[sfpDiagTCAStatusTxPower] => 2
[sfpDiagTCAStatusRxPower] => 3
[sfpDiagRSSIProfileId] => 65535
[sfpDiagRSSIState] => 1
[sfpDiagRSSIRxPowerAlmLow] => -20.00 dBm
[sfpDiagRSSIRxPowerAlmHigh] => -3.00 dBm
[sfpDiagRSSIRxPowerWarnLow] => -18.01 dBm
[sfpDiagRSSIRxPowerWarnHigh] => -5.00 dBm
[sfpDiagRSSITxPowerAlmLow] => -9.00 dBm
[sfpDiagRSSITxPowerAlmHigh] => -3.00 dBm
[sfpDiagRSSITxPowerWarnLow] => -8.11 dBm
[sfpDiagRSSITxPowerWarnHigh] => -3.90 dBm
[sfpDiagRSSITemperatureAlmLow] => -40.00 degree C
[sfpDiagRSSITemperatureAlmHigh] => 85.00 degree C
[sfpDiagRSSITemperatureWarnLow] => -30.00 degree C
[sfpDiagRSSITemperatureWarnHigh] => 75.00 degree C
[sfpDiagRSSIBiasAlmLow] => 0.00 mA
[sfpDiagRSSIBiasAlmHigh] => 60.00 mA
[sfpDiagRSSIBiasWarnLow] => 0.00 mA
[sfpDiagRSSIBiasWarnHigh] => 50.00 mA
[sfpDiagRSSIVoltageAlmLow] => 2.80 VDC
[sfpDiagRSSIVoltageAlmHigh] => 3.80 VDC
[sfpDiagRSSIVoltageWarnLow] => 2.90 VDC
[sfpDiagRSSIVoltageWarnHigh] => 3.70 VDC
[sfpDiagRSSIExtRxPowerAlmLow] => -40.00 dBm
[sfpDiagRSSIExtRxPowerAlmHigh] => -40.00 dBm
[sfpDiagRSSIExtRxPowerWarnLow] => -40.00 dBm
[sfpDiagRSSIExtRxPowerWarnHigh] => -40.00 dBm
[sfpDiagRSSIExtTxPowerAlmLow] => -40.00 dBm
[sfpDiagRSSIExtTxPowerAlmHigh] => -40.00 dBm
[sfpDiagRSSIExtTxPowerWarnLow] => -40.00 dBm
[sfpDiagRSSIExtTxPowerWarnHigh] => -40.00 dBm
[sfpDiagRSSIExtBiasAlmLow] => 0.00 mA
[sfpDiagRSSIExtBiasAlmHigh] => 0.00 mA
[sfpDiagRSSIExtBiasWarnLow] => 0.00 mA
[sfpDiagRSSIExtBiasWarnHigh] => 0.00 mA
[sfpDiagRSSIExtTemperatureAlmLow] => 0.00 degree C
[sfpDiagRSSIExtTemperatureAlmHigh] => 0.00 degree C
[sfpDiagRSSIExtTemperatureWarnLow] => 0.00 degree C
[sfpDiagRSSIExtTemperatureWarnHigh] => 0.00 degree C
–snip–
