Hey everyone:
Can anyone help me understand what this “Sensor under limit” alert means (highlighted in red in attached screen grab)?
If you go the affected device > Settings(Cog) > Health/Processors/Memory/ect
You’ll find a class where its ‘Current’ is under the ‘Low’ value thus alarming that its under limit.
seems that the low and high values are in millivolts, but the current value is in volts. There is a 10^3 gap ![]()
There is probably a fix to apply in the device support discovery process to fix this.
And you can fix it manually as explained above, but you’ll have to do it for every sensor of every device involved.
