I want to set the receive and transmit power thresholds for ports, for example 8/1; 8/2; 8/3; 8/4 transmit power attenuation threshold is 1 dBm and receiver power attenuation threshold is 8/1; 8/2; 8/3; April 8 is -24 dBm. When the receiving and transmitting power exceed the threshold, it will automatically issue an alarm.
I found the following tutorial article
But here they set up 1 XGiGaEthernet0/0/4 Rx port in sensors.sensor_desr. I want to set up multiple ports at the same time, how do I setup.
Looking forward to help, thank you for your attention.
