Hello… Does anyone have issues with LibreNMS having an issue with special characters? I have $ within my switch’s snmp config and it does not work. As soon as I remove the $ it is ok. Is this expected behavior?
Found this looks like was issue b4… idk if would help you.
opened 12:00PM - 28 Sep 16 UTC
closed 12:39PM - 03 Oct 16 UTC
Needs-Info
DO NOT DELETE THIS INFORMATION.
> Please read this information carefully.
- [ ]… Is your install up to date? [Updating your install](http://docs.librenms.org/General/Updating/)
Please do not submit an issue if your install is not up to date within the last 24 hours or on a stable monthly release.
- [ ] Please include all of the information between the `====================================` section of `./validate.php`.
- [ ] If you would like us to add a new device then please provide the information asked for [here](http://docs.librenms.org/Support/FAQ/#faq20)
- [ ] Please provide as much detail as possible.
I am having issues adding the device using the GUI while adding the same device using the CLI works without issues; see below. What could I be wrong?
laf
10 July 2017 20:54
#3
It should help as this isn’t an issue in librenms afaik. Either escape the characters or wrap them in quotes if doing it via the cli.
It doesn’t work cli or within librenms web frontend. Only if I don’t place the $ does it work. Then I can snmpwalk and use librenms.
laf
10 July 2017 21:01
#5
-bash-4.2$ ./addhost.php localhost.localdomain @bH\$\$Epq v2c
Added device localhost.localdomain (275)
