LibreNMS | 1.69-67-g2a98076
DB Schema | 2020_11_02_164331_add_powerstate_enum_to_vminfo (191)
PHP | 7.3.25
Python | 3.6.8
MySQL | 5.5.68-MariaDB
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
OpenSSL |
[OK] Composer Version: 2.0.7
Modified Files:
rrd/.gitignore
Trying to authenticate using group strategy.
I am able to auth with my provider when i enable group_strategy=static
but when I enable group_strategy=map
I don’t get access level 10
or Admin
but a lower access level…not sure which access level number
$config['auth_mechanism'] = "sso";
$config['sso']['mode'] = "header";
$config['sso']['create_users'] = true;
$config['sso']['update_users'] = true;
#$config['sso']['user_attr'] = 'REMOTE_USER'; // not needed since user_attr is already REMOTE_USER
$config['sso']['realname_attr'] = 'REMOTE_NAME';
$config['sso']['email_attr'] = 'REMOTE_EMAIL';
$config['sso']['group_attr'] = 'REMOTE_GROUPS';
$config['sso']['group_strategy'] = 'map';
$config['sso']['group_delimiter'] = ',';
$config['sso']['group_level_map'] = ['librenms-admins' => 10];
// works with below
$config['sso']['group_strategy'] = "static";
$config['sso']['static_level'] = 10;
Interestingly when I auth into librenms with strategy=static; level=10, and take a look at the /settings
page where all the configure global settings appear, (because im granted Admin rights), I only see a few sso
settings:
auth_mechanism sso
sso.create_users true
sso.update_users true
sso.user_attr REMOTE_USER
So not sure why I dont see the other sso settings as if they were not configured. Bug? But strategy=static, level=10
works fine…so i dont really understand where the disconnect is…
Any input is much appreciated.
Thank you,
Dave
