This is my ./validate.php
i set two php.ini from
nano /etc/php/8.1/fpm/php.ini
nano /etc/php/8.1/cli/php.ini
but it still show fail
and another command cant fix
Please give me some advice
| LibreNMS | 23.4.0 (2023-05-12T02:41:09+00:00) |
| DB Schema | 2023_04_12_174529_modify_ports_table (250) |
| PHP | 8.1.2-1ubuntu2.11 |
| Python | 3.10.6 |
| Database | MariaDB 10.6.12-MariaDB-0ubuntu0.22.04.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.1 |
[OK] Composer Version: 2.5.5
[OK] MySQl and PHP time match
[FAIL] You have no timezone set for php.
PHP: Runtime Configuration - Manual
[FAIL] No active polling method detected
[FAIL] Python wrapper cron entry is not present
[FAIL] Scheduler is not running
cp /opt/librenms/dist/librenms-scheduler.service /opt/librenms/dist/librenms-scheduler.timer /etc/systemd/system/
systemctl enable librenms-scheduler.timer
systemctl start librenms-scheduler.timer
[WARN] Global lnms shortcut not installed. lnms command must be run with full path
sudo ln -s /opt/librenms/lnms /usr/local/bin/lnms
[WARN] Bash completion not installed. lnms command tab completion unavailable.
sudo cp /opt/librenms/misc/lnms-completion.bash /etc/bash_completion.d/
warning: Not a git repository. Use --no-index to compare two paths outside a working tree
usage: git diff --no-index []
Diff output format options
-p, --patch generate patch
-s, --no-patch suppress diff output
-u generate patch
-U, --unified[=] generate diffs with lines context
-W, --function-context
–raw generate the diff in raw format
–patch-with-raw synonym for ‘-p --raw’
–patch-with-stat synonym for ‘-p --stat’
–numstat machine friendly --stat
–shortstat output only the last line of --stat
-X, --dirstat[=<param1,param2>…]
output the distribution of relative amount of changes for each sub-directory
–cumulative synonym for --dirstat=cumulative
–dirstat-by-file[=<param1,param2>…]
synonym for --dirstat=files,param1,param2…
–check warn if changes introduce conflict markers or whitespace errors
–summary condensed summary such as creations, renames and mode changes
–name-only show only names of changed files
–name-status show only names and status of changed files
–stat[=[,[,]]]
generate diffstat
–stat-width generate diffstat with a given width
–stat-name-width
generate diffstat with a given name width
–stat-graph-width
generate diffstat with a given graph width
–stat-count generate diffstat with limited lines
–compact-summary generate compact summary in diffstat
–binary output a binary diff that can be applied
–full-index show full pre- and post-image object names on the “index” lines
–color[=] show coloured diff
–ws-error-highlight
highlight whitespace errors in the ‘context’, ‘old’ or ‘new’ lines in the diff
-z do not munge pathnames and use NULs as output field terminators in --raw or --numstat
–abbrev[=] use digits to display object names
–src-prefix
show the given source prefix instead of “a/”
–dst-prefix
show the given destination prefix instead of “b/”
–line-prefix
prepend an additional prefix to every line of output
–no-prefix do not show any source or destination prefix
–inter-hunk-context
show context between diff hunks up to the specified number of lines
–output-indicator-new
specify the character to indicate a new line instead of ‘+’
–output-indicator-old
specify the character to indicate an old line instead of ‘-’
–output-indicator-context
specify the character to indicate a context instead of ’ ’
Diff rename options
-B, --break-rewrites[=[/]]
break complete rewrite changes into pairs of delete and create
-M, --find-renames[=]
detect renames
-D, --irreversible-delete
omit the preimage for deletes
-C, --find-copies[=]
detect copies
–find-copies-harder use unmodified files as source to find copies
–no-renames disable rename detection
–rename-empty use empty blobs as rename source
–follow continue listing the history of a file beyond renames
-l prevent rename/copy detection if the number of rename/copy targets exceeds given limit
Diff algorithm options
–minimal produce the smallest possible diff
-w, --ignore-all-space
ignore whitespace when comparing lines
-b, --ignore-space-change
ignore changes in amount of whitespace
–ignore-space-at-eol
ignore changes in whitespace at EOL
–ignore-cr-at-eol ignore carrier-return at the end of line
–ignore-blank-lines ignore changes whose lines are all blank
-I, --ignore-matching-lines
ignore changes whose all lines match
–indent-heuristic heuristic to shift diff hunk boundaries for easy reading
–patience generate diff using the “patience diff” algorithm
–histogram generate diff using the “histogram diff” algorithm
–diff-algorithm
choose a diff algorithm
–anchored generate diff using the “anchored diff” algorithm
–word-diff[=] show word diff, using to delimit changed words
–word-diff-regex
use to decide what a word is
–color-words[=]
equivalent to --word-diff=colour --word-diff-regex=
–color-moved[=]
moved lines of code are coloured differently
–color-moved-ws
how white spaces are ignored in --color-moved
Other diff options
–relative[=]
when run from subdir, exclude changes outside and show relative paths
-a, --text treat all files as text
-R swap two inputs, reverse the diff
–exit-code exit with 1 if there were differences, 0 otherwise
–quiet disable all output of the program
–ext-diff allow an external diff helper to be executed
–textconv run external text conversion filters when comparing binary files
–ignore-submodules[=]
ignore changes to submodules in the diff generation
–submodule[=]
specify how differences in submodules are shown
–ita-invisible-in-index
hide ‘git add -N’ entries from the index
–ita-visible-in-index
treat ‘git add -N’ entries as real in the index
-S look for differences that change the number of occurrences of the specified string
-G look for differences that change the number of occurrences of the specified regex
–pickaxe-all show all changes in the changeset with -S or -G
–pickaxe-regex treat in -S as extended POSIX regular expression
-O control the order in which files appear in the output
–rotate-to show the change in the specified path first
–skip-to skip the output to the specified path
–find-object
look for differences that change the number of occurrences of the specified object
–diff-filter [(A|C|D|M|R|T|U|X|B)…[*]]
select files by diff type
–output Output to a specific file
[FAIL] Failed to fetch version from local git: fatal: detected dubious ownership in repository at ‘/opt/librenms’
To add an exception for this directory, call:
git config --global --add safe.directory /opt/librenms
You can switch back to master with git checkout master
[FAIL] You need to run this script as ‘librenms’ or root
strong text
