Hi all,
i am using distributed polling. Some switches some times are showing “Down” on Devices panel. But after few mins, they come back to “UP” with the correct up time (for example: 103d 4h 12m).
I can ping the switches during switches are showing down on LibreNMS Devices Panel
Please give me an advice.
Jeff Deng
Regards
Jeff Deng
Are the pollers completing the polling cycle of the device ?
In the eventlog for that device, does it perhaps state “Status changed to ‘down’ from SNMP check”? This indicates that the snmp communication is lost. A device can show offline for 2 reasons, ICMP check and SNMP check. The latter being the one I think you are facing, because you are stating the devices are pinging back. I would look at whether you can reach a device with snmpwalk commands during this time, to see if the device’s snmp engine is up and running and if the result is indeed a false indication in LNMS. In my experience, LNMS has been correct most of the time when reporting down/up status.
Thank you guys. The issue has been resolved. It was ICMP and SNMP communication problem between devices and distributed pollers.
