docker:1:Script returned exception: Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get http://%2Fvar%2Frun%2Fdocker.sock/v1.24/version: dial unix /var/run/docker.sock: connect: permission denied
SQL[UPDATE `applications` set `app_state`=?,`app_status`=?,`timestamp`=NOW() WHERE `app_id` = ? ["OK","",97] 3.6ms]
I had this issue with the dockerized-mailcow app when I ran sudo chmod 666 /var/run/docker.sock it’s solved the issue, but after restarts and so on it will change the ownership and it stops work.
