From the command line if I run ./validate.php I will get an error at the end stating I need to run as root, however, if I run as root, I get an error stating do not run as root. Anyone else seeing this?
See below:
asg@librenms:/opt/librenms$ sudo ./daily.sh
[sudo] password for asg:
Fetching new release information OK
Between releases, waiting for newer release
Updating Composer packages OK
Updated from unset to OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
Caching Mac OUI data OK
asg@librenms:/opt/librenms$ ./validate.php
Component | Version |
LibreNMS | 23.2.0-44-g0a889ad36 (2023-03-23T21:29:53-04:00) |
DB Schema | 2023_03_14_130653_migrate_empty_user_funcs_to_null (249) |
PHP | 8.1.7-1ubuntu3.3 |
Python | 3.10.7 |
Database | MariaDB 10.6.12-MariaDB-0ubuntu0.22.10.1 |
RRDTool | 1.7.2 |
SNMP | 5.9.3 |
[OK] Composer Version: 2.5.5
[OK] MySQl and PHP time match
[FAIL] You need to run this script as ‘librenms’ or root
asg@librenms:/opt/librenms$ sudo ./validate.php
Do not run validate.php as root
