I am trying to make a new OS for Eltek power system platform. Actually the os works pretty well but I have troubles to finalize librenms tests. collect-snmp-data.php tries to find values snmpEngineTime.0 and hrSystemUptime.0 and there is no that kind of values at all. Is there clever way to solve this?
Oids .1.3.6.1.6.3.10.2.1.3.0 and .1.3.6.1.2.1.25.1.1.0 are outside of the range.
What I have understood wrong?
-Mikael
–DEBUG–
(venv) librenms@librenms:~$ ./scripts/collect-snmp-data.php -h 192.168.100.21 -o eltek -d
OS: eltek
Module(s): all
Capturing Data: Updating os_def.cache… Done
Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: snmpEngineTime.0
192.168.100.21 75 eltek [FPING] /usr/bin/fping -e -q -c 3 -p 500 -t 500 192.168.100.21
Array
[xmt] => 3
[rcv] => 3
[loss] => 0
[min] => 0.26
[max] => 0.33
[avg] => 0.28
[exitcode] => 0
SNMP Check response code: 0
Attempting to initialize OS: eltek
OS initilized as Generic
Modules status: Global+ OS Device
Load disco module core
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OUQn -m SNMPv2-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/eltek:/opt/librenms/mibs/eltek udp:HOSTNAME:161 sysName.0 sysObjectID.0 sysDescr.0]
...0 = sysName
...0 = ..4.1.12148.9
..*.0 = WebPower(402414.003) 4.11, Apr 4 2016 OS:2.7
Runtime for discovery module ‘core’: 0.0320 seconds with 1080 bytes
SNMP: [2/0.06s] MySQL: [6/0.02s] RRD: [0/0.00s]
Unload disco module core
Modules status: Global+ OS- Device Module [ os ] disabled on os.
Modules status: Global+ OS- Device Module [ ports ] disabled on os.
Modules status: Global+ OS- Device Module [ ports-stack ] disabled on os.
Modules status: Global+ OS- Device Module [ entity-physical ] disabled on os.
Modules status: Global- OS- Device Module [ entity-state ] disabled on os.
Modules status: Global+ OS- Device Module [ processors ] disabled on os.
Modules status: Global+ OS- Device Module [ mempools ] disabled on os.
Modules status: Global+ OS- Device Module [ cisco-vrf-lite ] disabled on os.
Modules status: Global- OS- Device Module [ cisco-mac-accounting ] disabled on os.
Modules status: Global- OS- Device Module [ cisco-pw ] disabled on os.
Modules status: Global- OS- Device Module [ vrf ] disabled on os.
Modules status: Global- OS- Device Module [ cisco-cef ] disabled on os.
Modules status: Global- OS- Device Module [ cisco-sla ] disabled on os.
Modules status: Global- OS- Device Module [ cisco-cbqos ] disabled on os.
Modules status: Global- OS- Device Module [ cisco-otv ] disabled on os.
Modules status: Global+ OS- Device Module [ ipv4-addresses ] disabled on os.
Modules status: Global+ OS- Device Module [ ipv6-addresses ] disabled on os.
Modules status: Global- OS- Device Module [ route ] disabled on os.
Modules status: Global+ OS- Device Module [ sensors ] disabled on os.
Modules status: Global+ OS- Device Module [ storage ] disabled on os.
Modules status: Global+ OS- Device Module [ hr-device ] disabled on os.
Modules status: Global+ OS- Device Module [ discovery-protocols ] disabled on os.
Modules status: Global+ OS- Device Module [ arp-table ] disabled on os.
Modules status: Global- OS- Device Module [ discovery-arp ] disabled on os.
Modules status: Global- OS- Device Module [ junose-atm-vp ] disabled on os.
Modules status: Global+ OS- Device Module [ bgp-peers ] disabled on os.
Modules status: Global+ OS- Device Module [ vlans ] disabled on os.
Modules status: Global- OS- Device Module [ vmware-vminfo ] disabled on os.
Modules status: Global- OS- Device Module [ libvirt-vminfo ] disabled on os.
Modules status: Global- OS- Device Module [ toner ] disabled on os.
Modules status: Global+ OS- Device Module [ ucd-diskio ] disabled on os.
Modules status: Global- OS- Device Module [ applications ] disabled on os.
Modules status: Global+ OS- Device Module [ services ] disabled on os.
Modules status: Global+ OS- Device Module [ stp ] disabled on os.
Modules status: Global+ OS- Device Module [ ntp ] disabled on os.
Modules status: Global- OS- Device Module [ loadbalancers ] disabled on os.
Modules status: Global- OS- Device Module [ mef ] disabled on os.
Modules status: Global+ OS- Device Module [ wireless ] disabled on os.
Modules status: Global+ OS- Device Module [ fdb-table ] disabled on os.
Discovered in 1.123 seconds
Hostname: 192.168.100.21
Device ID: 75
OS: eltek
Array
[xmt] => 3
[rcv] => 3
[loss] => 0
[min] => 0.22
[max] => 0.46
[avg] => 0.34
[exitcode] => 0
Load poller module core
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OQnUt -m SNMPv2-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/eltek:/opt/librenms/mibs/eltek udp:HOSTNAME:161 sysUpTime.0 sysLocation.0 sysContact.0 sysName.0 sysObjectID.0 sysDescr.0]
...0 = 52752841
...0 = sysLocation
...0 = sysContact
...0 = sysName
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OQnUst -m HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/eltek:/opt/librenms/mibs/eltek udp:HOSTNAME:161 snmpEngineTime.0 hrSystemUptime.0]
Uptime seconds: 527528
RRD[update /opt/librenms/rrd/192.168.100.21/uptime.rrd N:527528]
Uptime: 6 days, 2h 32m 8s
Google geocode engine being used
Bad lat / lng received
Runtime for poller module ‘core’: 0.2693 seconds with 16000 bytes
SNMP: [2/0.08s] MySQL: [1/0.00s] RRD: [0/0.00s]
Unload poller module core
RRD[update /opt/librenms/rrd/192.168.100.21/poller-perf-core.rrd N:0.26926803588867]
Modules status: Global- OS- Device Module [ unix-agent ] disabled on os.
Modules status: Global+ OS- Device Module [ ipmi ] disabled on os.
Modules status: Global+ OS- Device Module [ netstats ] disabled on os.
Modules status: Global+ OS- Device Module [ hr-mib ] disabled on os.
Modules status: Global+ OS- Device Module [ ucd-mib ] disabled on os.
Modules status: Global+ OS- Device Module [ ipSystemStats ] disabled on os.
Modules status: Global- OS- Device Module [ wifi ] disabled on os.
Modules status: Global+ OS- Device Module [ ospf ] disabled on os.
Modules status: Global- OS- Device Module [ cisco-ipsec-flow-monitor ] disabled on os.
Modules status: Global- OS- Device Module [ cisco-remote-access-monitor ] disabled on os.
Modules status: Global- OS- Device Module [ cipsec-tunnels ] disabled on os.
Modules status: Global- OS- Device Module [ cisco-ace-loadbalancer ] disabled on os.
Modules status: Global- OS- Device Module [ cisco-ace-serverfarms ] disabled on os.
Modules status: Global- OS- Device Module [ cisco-asa-firewall ] disabled on os.
Modules status: Global- OS- Device Module [ cisco-voice ] disabled on os.
Modules status: Global- OS- Device Module [ cisco-vpdn ] disabled on os.
Modules status: Global- OS- Device Module [ netscaler-vsvr ] disabled on os.
Modules status: Global- OS- Device Module [ aruba-controller ] disabled on os.
Modules status: Global+ OS- Device Module [ applications ] disabled on os.
Modules status: Global- OS- Device Module [ mib ] disabled on os.
Start Device Groups
Groups Added:
Groups Removed:
End Device Groups
Enabling graphs: uptime
RRD[update /opt/librenms/rrd/192.168.100.21/ping-perf.rrd N:0.34]
RRD[update /opt/librenms/rrd/192.168.100.21/poller-perf.rrd N:1.342]
Updating 192.168.100.21
Polled in 1.342 seconds
OIDs to capture Array
[sysDescr.0_get] => Array
[oid] => sysDescr.0
[mib] => SNMPv2-MIB
[method] => get
[sysObjectID.0_get] => Array
[oid] => sysObjectID.0
[mib] => SNMPv2-MIB
[method] => get
[sysName.0_get] => Array
[oid] => sysName.0
[mib] => SNMPv2-MIB
[method] => get
[sysUpTime.0_get] => Array
[oid] => sysUpTime.0
[mib] => SNMPv2-MIB
[method] => get
[sysLocation.0_get] => Array
[oid] => sysLocation.0
[mib] => SNMPv2-MIB
[method] => get
[sysContact.0_get] => Array
[oid] => sysContact.0
[mib] => SNMPv2-MIB
[method] => get
[snmpEngineTime.0_get] => Array
[oid] => snmpEngineTime.0
[mib] => HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB
[method] => get
[hrSystemUptime.0_get] => Array
[oid] => hrSystemUptime.0
[method] => get
sysDescr.0SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OUneb -Ih -m SNMPv2-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/eltek:/opt/librenms/mibs/eltek udp:HOSTNAME:161 sysDescr.0]
...0 = STRING: "WebPower(402414.003) 4.11, Apr 4 2016 OS:2.7 "
sysObjectID.0SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OUneb -Ih -m SNMPv2-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/eltek:/opt/librenms/mibs/eltek udp:HOSTNAME:161 sysObjectID.0]
...0 = OID: .*.4.1.12148.9
sysName.0SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OUneb -Ih -m SNMPv2-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/eltek:/opt/librenms/mibs/eltek udp:HOSTNAME:161 sysName.0]
...0 = STRING: “sysName”
sysUpTime.0SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OUneb -Ih -m SNMPv2-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/eltek:/opt/librenms/mibs/eltek udp:HOSTNAME:161 sysUpTime.0]
...0 = Timeticks: (52752882) 6 days, 2:32:08.82
sysLocation.0SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OUneb -Ih -m SNMPv2-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/eltek:/opt/librenms/mibs/eltek udp:HOSTNAME:161 sysLocation.0]
...0 = STRING: “sysLocation”
sysContact.0SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OUneb -Ih -m SNMPv2-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/eltek:/opt/librenms/mibs/eltek udp:HOSTNAME:161 sysContact.0]
...0 = STRING: “sysContact”
snmpEngineTime.0SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OUneb -Ih -m HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/eltek:/opt/librenms/mibs/eltek udp:HOSTNAME:161 snmpEngineTime.0]
Error in packet
Failed object: .1.3.6.1.6.3.10.2.1.3.0
hrSystemUptime.0SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -OUneb -Ih -m HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/eltek:/opt/librenms/mibs/eltek udp:HOSTNAME:161 hrSystemUptime.0]
Error in packet
Failed object: .1.3.6.1.2.1.25.1.1.0
Updated snmprec data /opt/librenms/tests/snmpsim/eltek.snmprec
Verify this file does not contain any private data before submitting!
–DEBUG–
