Hi everyone,
im trying to set the syslog server on the librenms server but i cant make it work.
the syslog-ng getting the messages as it should, i set up another destination path to file in order to see the incoming messages with the template.
example of the message:
192.168.190.172||user||notice||notice||0d||2019-11-25 13:44:24||- pid=20034 user=root folder=/Common module=(tmos)# status=[Command OK] cmd_data=save / sys config partitions all||AUDIT
the host is 192.168.190.172 and this is the same as configured under devices.
i have added the following line to config.php
$config['enable_syslog'] = 1;
i have no SElinux on my server.
as you can see, no syslog tab under logs only eventlog:
my syslog-ng config file is the same as the documentation:
@version:3.5 @include "scl.conf" # syslog-ng configuration file. # # This should behave pretty much like the original syslog on RedHat. But # it could be configured a lot smarter. # # See syslog-ng(8) and syslog-ng.conf(5) for more information. # # Note: it also sources additional configuration files (*.conf) # located in /etc/syslog-ng/conf.d/ options { chain_hostnames(off); flush_lines(0); use_dns(no); use_fqdn(no); owner("root"); group("adm"); perm(0640); stats_freq(0); bad_hostname("^gconfd$"); }; source s_sys { system(); internal(); }; source s_net { tcp(port(514) flags(syslog-protocol)); udp(port(514) flags(syslog-protocol)); }; ######################## # Destinations ######################## destination d_librenms { program("/opt/librenms/syslog.php" template ("$HOST||$FACILITY||$PRIORITY||$LEVEL||$TAG||$R_YEAR-$R_MONTH-$R_DAY $R_HOUR:$R_MIN:$R_SEC||$MSG||$PROGRAM\n") template-escape(yes)); }; filter f_kernel { facility(kern); }; filter f_default { level(info..emerg) and not (facility(mail) or facility(authpriv) or facility(cron)); }; filter f_auth { facility(authpriv); }; filter f_mail { facility(mail); }; filter f_emergency { level(emerg); }; filter f_news { facility(uucp) or (facility(news) and level(crit..emerg)); }; filter f_boot { facility(local7); }; filter f_cron { facility(cron); }; ######################## # Log paths ######################## log { source(s_net); source(s_sys); destination(d_librenms); }; # Source additional configuration files (.conf extension only) @include "/etc/syslog-ng/conf.d/*.conf" # vim:ft=syslog-ng:ai:si:ts=4:sw=4:et:
how can i check why ibrenms is not importing the logs to the device?
