Telegram Alert is failed but ./scripts/test-alert.php -h 172.168.15.77 -d -r 24 showing every thing OK
No alert is generating based on the event but if initiated via ./scripts/test-alert.php -h -d -r getting alert and the same is updating in the event log
[librenms@localhost ~]$ ./validate.php
LibreNMS 24.5.0-11-gc7708922a (2024-05-23T08:33:51+05:30)
DB Schema 2024_04_29_183605_custom_maps_drop_background_suffix_and_background_version (294)
PHP 8.1.28
Python 3.6.8
Database MariaDB 10.3.28-MariaDB
RRDTool 1.7.0
SNMP 5.8
[OK] Composer Version: 2.7.6
[FAIL] Some poller nodes have not checked in recently
Inactive Nodes:
nms
Modified Files:
bootstrap/cache/.gitignore
html/images/librenms_logo_blue.svg
html/images/librenms_logo_dark.svg
html/images/librenms_logo_light.svg
html/images/librenms_logo_mono.svg
html/images/os/generic.svg
html/images/os/vsolution.png
logs/.gitignore
rrd/.gitignore
storage/app/.gitignore
storage/app/public/.gitignore
storage/debugbar/.gitignore
and 3 more…
[librenms@localhost ~]$ ./scripts/test-alert.php -h 172.168.15.77 -d -r 24
SQL[select * from devices where hostname = ? limit 1 [“172.168.15.77”] 0.39ms]
SQL[SELECT alerts.id, alerts.alerted, alerts.device_id, alerts.rule_id, alerts.state, alerts.note, alerts.info FROM alerts WHERE alerts.device_id = 27 && alerts.rule_id = 24 0.23ms]
SQL[SELECT alert_log.id,alert_log.rule_id,alert_log.device_id,alert_log.state,alert_log.details,alert_log.time_logged,alert_rules.rule,alert_rules.severity,alert_rules.extra,alert_rules.name,alert_rules.query,alert_rules.builder,alert_rules.proc FROM alert_log,alert_rules WHERE alert_log.rule_id = alert_rules.id && alert_log.device_id = ? && alert_log.rule_id = ? && alert_rules.disabled = 0 ORDER BY alert_log.id DESC LIMIT 1 [27,24] 0.26ms]
SQL[SELECT DISTINCT a.* FROM alert_rules a
LEFT JOIN alert_device_map d ON a.id=d.rule_id AND (a.invert_map = 0 OR a.invert_map = 1 AND d.device_id = ?)
LEFT JOIN alert_group_map g ON a.id=g.rule_id AND (a.invert_map = 0 OR a.invert_map = 1 AND g.group_id IN (SELECT DISTINCT device_group_id FROM device_group_device WHERE device_id = ?))
LEFT JOIN alert_location_map l ON a.id=l.rule_id AND (a.invert_map = 0 OR a.invert_map = 1 AND l.location_id IN (SELECT DISTINCT location_id FROM devices WHERE device_id = ?))
LEFT JOIN devices ld ON l.location_id=ld.location_id AND ld.device_id = ?
LEFT JOIN device_group_device dg ON g.group_id=dg.device_group_id AND dg.device_id = ?
WHERE a.disabled = 0 AND (
(d.device_id IS NULL AND g.group_id IS NULL AND l.location_id IS NULL)
OR (a.invert_map = 0 AND (d.device_id=? OR dg.device_id=? OR ld.device_id=?))
OR (a.invert_map = 1 AND (d.device_id != ? OR d.device_id IS NULL) AND (dg.device_id != ? OR dg.device_id IS NULL) AND (ld.device_id != ? OR ld.device_id IS NULL))
) [27,27,27,27,27,27,27,27,27,27,27] 0.89ms]
SQL[select * from locations where locations.id = ? limit 1 [159] 0.15ms]
SQL[select * from devices_attribs where devices_attribs.device_id = ? and devices_attribs.device_id is not null [27] 0.15ms]
RRD[lastupdate /opt/librenms/rrd/172.168.15.77/icmp-perf.rrd ]
SQL[select * from alert_templates where exists (select * from alert_template_map where alert_templates.id = alert_template_map.alert_templates_id and alert_rule_id = ?) limit 1 [24] 0.33ms]
SQL[select * from alert_templates where name = ? limit 1 [“Default Alert Template”] 0.12ms]
Issuing Alert-UID #726520/1:
SQL[SELECT rule_id FROM alerts WHERE id=? [3917] 0.1ms]
SQL[SELECT b.transport_id, b.transport_type, b.transport_name FROM alert_transport_map AS a LEFT JOIN alert_transports AS b ON b.transport_id=a.transport_or_group_id WHERE a.target_type=‘single’ AND a.rule_id=? UNION DISTINCT SELECT d.transport_id, d.transport_type, d.transport_name FROM alert_transport_map AS a LEFT JOIN alert_transport_groups AS b ON a.transport_or_group_id=b.transport_group_id LEFT JOIN transport_group_transport AS c ON b.transport_group_id=c.transport_group_id LEFT JOIN alert_transports AS d ON c.transport_id=d.transport_id WHERE a.target_type=‘group’ AND a.rule_id=? [24,24] 0.28ms]
:: Transport telegram => SQL[select * from alert_transports where alert_transports.transport_id = ? limit 1 [2] 0.12ms]
OKSQL[insert into eventlog (reference, type, datetime, severity, message, username, device_id) values (?, ?, ?, ?, ?, ?, ?) [null,“alert”,“2024-05-26 13:34:37”,0,“Issued warning alert for rule ‘Testxxxxx’ to transport ‘telegram’”,“”,27] 0.69ms]
Please help
