Template variable expansion vs $obj
Hello!,
I’m trying to implement a new transport, and want to move as much as possible to templates. Can anybody confirm if all the variables available in the transport as $obj[‘var’] should be available within templates?.
I’m trying to figure why {{ $alert->rule }} doesn’t expand, but $obj[‘rule’] does
[email protected]:~> ./validate.php
LibreNMS 22.8.0
DB Schema 2022_07_19_081224_plugins_unique_index (244)
PHP 8.1.10
Python 3.6.15
Database MariaDB 10.6.8-MariaDB
RRDTool 1.7.0
SNMP 5.7.3
[OK] Composer Version: 2.4.1
[OK]
[OK] MySQl and PHP time match
[WARN] Using database for locking, you should set CACHE_DRIVER=redis
[WARN] Your install is over 24 hours out of date, last update: Tue, 06 Sep 2022 21:43:51 +0000
The template has already been run by the time the transport is called.
Why would you need to access transport variables within the template? Doing that would make a template locked to a transport, breaking with other transports.
Hello!, is the other way around. I would like to include rule ID in the message. According to the documentation (Templates - LibreNMS Docs) $alert->rule should be available in a template, but doesn’t seem to be the case.
If I define in the template {{ $alert-> rule }} within the template, the ID is not passed to the transport.
Perhaps a bug?
PR sent as Fix reference to Rule ID by ciroiriarte · Pull Request #14344 · librenms/librenms · GitHub
