I’m replacing many network equipments. I remove the old ones and then I add the new ones. It was working fine until I got to one that I cannot delete, I get timeout error in web mode. The device is ID 519.
I tried to run the following command in SSH :
lnms device:remove [devicename]
It returns the following message :
In Connection.php line 822:
SQLSTATE[HY000]: General error: 1205 Lock wait timeout exceeded; try restarting transaction (Connection: mysql, SQL: delete from syslog where syslog.device_id = 519 and syslog.
device_id is not null)
In Connection.php line 593:
I tried the following command in MySQL :
MariaDB [librenms]> delete from syslog where syslog.device_id=519 and syslog.device_id is not null;
ERROR 1205 (HY000): Lock wait timeout exceeded; try restarting transaction
Here’s my validate.php :
| LibreNMS | 25.8.0-dev.25+b481497ba (2025-08-05T04:05:55-04:00) |
| DB Schema | 2025_07_10_201918_update_vlans_table (353) |
| PHP | 8.3.14 |
| Python | 3.12.3 |
| Database | MariaDB 10.11.13-MariaDB-0ubuntu0.24.04.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.4.pre2 |
| [OK] Composer Version: 2.8.10 | |
| [OK] Dependencies up-to-date. | |
| [OK] Database Connected | |
| [OK] Database Schema is current | |
| [OK] SQL Server meets minimum requirements | |
| [OK] lower_case_table_names is enabled | |
| [OK] MySQL engine is optimal | |
| [OK] Database and column collations are correct | |
| [OK] Database schema correct | |
| [OK] MySQL and PHP time match | |
| [OK] Distributed Polling setting is enabled globally | |
| [OK] Connected to rrdcached | |
| [OK] Active pollers found | |
| [OK] Dispatcher Service is enabled | |
| [OK] Locks are functional | |
| [OK] Python wrapper cron entry is not present | |
| [OK] Redis is functional | |
| [OK] rrdtool version ok | |
What can I do to remove this device ?
