For comware-based switches, there are two values that can be read that would help knowing if the switch has an unsaved configuration. hh3cCfgRunModifiedLast is a timetick that is a recorded value of sysuptime when the configuration was last modified. hh3cCfgRunSavedLast on the other hand is a recorded value of sysuptime when the configuration was last saved to startup.
By comparing these values, you can know if a switch’s configuration has been modified but not saved. I would like to be able to create an alert when there’s an unsaved alert older than let’s say 24 hrs. I have successfully been able to get the values to LibreNMS but now my head is blank when it comes to how I would create the alert. Can anyone help?
