./validate.php
| LibreNMS | 25.1.0-82-g61efc4511 (2025-02-01T16:08:16-08:00) |
| DB Schema | 2025_01_30_000121_add_ifindex_index_to_ports_table (314) |
| PHP | 8.2.7 |
| Python | 3.8.10 |
| Database | MariaDB 10.3.39-MariaDB-0ubuntu0.20.04.2 |
| RRDTool | 1.7.2 |
| SNMP | 5.8 |
[OK] Composer Version: 2.8.5
[WARN] Your install is over 24 hours out of date, last update: Sun, 02 Feb 2025 00:08:16 +0000
Modified Files:
LibreNMS/Billing.php
rrd/.gitignore
I turned off daily.sh because of issue.
All my Traffic Bills disappeared on Feb 1st.
I was able to get current back by updating this line in /opt/librenms/LibreNMS/Billing.php
#return $cur_used / $since * $total;
return ($since == 0) ? 0 : ($cur_used / $since * $total);
But now my previous months Traffic Bills do not appear. I can see the data in the database but neither API or WebUI is showing data.
I don’t know what else to check and really need to get the billing back as we have to show to our end users and billing group for overages.
