Just wanted to see if anyone else notices this with their equipment,
On the same link, check both devices, Max aggregate is different depending which side you look from. So “Out” on one side, “In” on the other should be the same number. (but sometimes up to a few Gbps difference for me)
Wondering if it could be due to the two devices being polled at different 5 minute intervals, so the Max values are different depending on when the device is polled? (but you would expect the same peak traffic would be still captured on both?)
