Transport Jira - Test to jira failed - general error
A few months ago I set up a Transport to create tickets in Jira from a librenms alert and everything was working fine.
Now, in the production librenms server, I have tried to perform the same configuration but it gives an error when performing the Transport test:
In the log it shows this error:
[2021-10-29 08:38:56] production.ERROR: Illegal string offset ‘bill_id’ {“userId”: 2, “exception”: "[object] (ErrorException (code: 0): Illegal string offset 'bill_id 'at /opt/librenms/LibreNMS/Alert/AlertUtil.php:96)
[stacktrace]
0 /opt/librenms/LibreNMS/Alert/AlertUtil.php(96): Illuminate \ Foundation \ Bootstrap \ HandleExceptions-> handleError (2, ‘Illegal string …’, '/ opt / librenms / L. … ', 96, Array)
1 /opt/librenms/app/Http/Controllers/AlertTransportController.php(34): LibreNMS \ Alert \ AlertUtil :: getContacts (Array)
2 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): App \ Http \ Controllers \ AlertTransportController-> test (Object (Illuminate \ Http \ Request) , Object (App \ Models \ AlertTransport))
3 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate \ Routing \ Controller-> callAction (‘test’, Array)
4 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Route.php(262): Illuminate \ Routing \ ControllerDispatcher-> dispatch (Object (Illuminate \ Routing \ Route), Object ( App \ Http \ Controllers \ AlertTransportController), ‘test’) [2021-10-29 08:38:56] production.ERROR: Illegal string offset ‘bill_id’ {“userId”: 2, “exception”: " [object] (ErrorException (code: 0): Illegal string offset ‘bill_id’ at /opt/librenms/LibreNMS/Alert/AlertUtil.php:96)
[stacktrace]
Has anything changed in the librenms code lately so that it doesn’t work? I don’t have much knowledge of PHP to understand the problem.
It has a solution?
Thanks, regards
https://github.com/librenms/librenms/pull/13446 might fix you.
Additionally, these failures are only affect the test option, not actual alert delivery.
I have tried to generate an alert so that the transport of jira is executed but it does not work either.
Thank you anyway
