Hey thank you,
Here is the Data Base output, discovery.php and pics
select * from sensors where device_id = ‘995’;
8830 | 0 | current | 995 | snmp | .1.3.6.1.2.1.33.1.4.4.1.3.1 | 1 | rfc1628 | Output | 10 | 1 | 0.6 | 1.05 | NULL | NULL | NULL | 1 | No | NULL | NULL | 2017-05-18 08:12:56 | 0.6 |
./discovery.php -h 172.30.15.98 -d
LibreNMS Discovery
Version info:
Commit SHA: a475069c9bc768857876e4ec5c4aee0176690af5
Commit Date: 1493858725
DB Schema: 189
PHP: 7.0.18
MySQL: 5.5.52-MariaDB
RRDTool: 1.4.8
SNMP: NET-SNMP 5.7.2
DB Schema update started…
SQL[SELECT version FROM dbSchema
ORDER BY version DESC LIMIT 1]
DB Schema already up to date.
SQL[SELECT * FROM devices
WHERE status = 1 AND disabled = 0 AND hostname
LIKE ‘172.30.15.98’ ORDER BY device_id DESC]
SQL[SELECT * FROM devices_attribs WHERE device_id
= ‘995’]
172.30.15.98 995 poweralert SQL[INSERT INTO device_perf
(xmt
,rcv
,loss
,min
,max
,avg
,device_id
,timestamp
) VALUES (‘3’,‘3’,‘0’,‘0.91’,‘1.49’,‘1.29’,‘995’,NOW())]
SNMP Check response code: 0
Modules status: Global+ OS+ Device
#### Load disco module os ####
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Ovq -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 SNMPv2-MIB::sysDescr.0]
POWERALERT 12
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Ovqn -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 SNMPv2-MIB::sysObjectID.0]
.*.4.1.850.1
| POWERALERT 12 | .1.3.6.1.4.1.850.1 |
>> Runtime for discovery module 'os': 0.1280 seconds with 888 bytes
#### Unload disco module os ####
#### Load disco module ports ####
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 ifDescr]
ifDescr.1 = eth0
ifDescr.2 = LOOPBACK
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 ifName]
ifName = No Such Object available on this agent at this OID
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 ifAlias]
ifAlias = No Such Object available on this agent at this OID
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 ifType]
ifType.1 = softwareLoopback
ifType.2 = ethernetCsmacd
Array
[1] => Array
[ifDescr] => eth0
[ifType] => softwareLoopback
[2] => Array
[ifDescr] => LOOPBACK
[ifType] => ethernetCsmacd
SQL[SELECT `name` FROM `port_association_mode` WHERE pom_id = '1']
SQL[SELECT * FROM `ports` WHERE `device_id` = '995' ORDER BY port_id]
>> Runtime for discovery module 'ports': 1.9070 seconds with 2056 bytes
#### Unload disco module ports ####
Modules status: Global+ OS- Device Module [ ports-stack ] disabled on os.
Modules status: Global+ OS- Device Module [ entity-physical ] disabled on os.
#### Load disco module processors ####
hrDevice: SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m HOST-RESOURCES-MIB:HOST-RESOURCES-TYPES -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 hrDevice]
hrDevice = No Such Object available on this agent at this OID
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m HOST-RESOURCES-MIB:HOST-RESOURCES-TYPES -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 hrProcessorLoad]
hrProcessorLoad = No Such Object available on this agent at this OID
SQL[SELECT COUNT(*) FROM `processors` WHERE `device_id` = '995' AND `processor_type` != 'ucd-old']
SQL[SELECT * FROM `processors` WHERE `device_id` = '995']
>> Runtime for discovery module 'processors': 1.8530 seconds with 34936 bytes
#### Unload disco module processors ####
#### Load disco module mempools ####
SQL[SELECT COUNT(*) FROM `mempools` WHERE `device_id` = '995' AND `mempool_type` = 'cemp']
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m NETSWITCH-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert:/opt/librenms/mibs/hp udp:HOSTNAME:161 hpLocal]
hpLocalMem = No Such Object available on this agent at this OID
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m NETSWITCH-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert:/opt/librenms/mibs/hp udp:HOSTNAME:161 hpGlobal]
hpGlobalMem = No Such Object available on this agent at this OID
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m HOST-RESOURCES-MIB:HOST-RESOURCES-TYPES:NetWare-Host-Ext-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 hrStorageEntry]
hrStorageEntry = No Such Object available on this agent at this OID
SQL[SELECT * FROM `mempools` WHERE `device_id` = '995']
>> Runtime for discovery module 'mempools': 1.2210 seconds with 23112 bytes
#### Unload disco module mempools ####
Modules status: Global+ OS- Device Module [ cisco-vrf-lite ] disabled on os.
Modules status: Global- OS- Device Module [ cisco-mac-accounting ] disabled on os.
Modules status: Global- OS- Device Module [ cisco-pw ] disabled on os.
Modules status: Global- OS- Device Module [ cisco-vrf ] disabled on os.
Modules status: Global- OS Device Module [ cisco-cef ] disabled globally.
Modules status: Global- OS- Device Module [ cisco-sla ] disabled on os.
Modules status: Global- OS Device Module [ cisco-cbqos ] disabled globally.
Modules status: Global- OS Device Module [ cisco-otv ] disabled globally.
#### Load disco module ipv4-addresses ####
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -Osq -m IP-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 ipAdEntIfIndex]
ipAdEntIfIndex.* 1
ipAdEntIfIndex.* 2
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -m IP-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 ipAdEntNetMask.127.0.0.1]
SQL[SELECT COUNT(*) FROM `ports` WHERE device_id = '995' AND `ifIndex` = '1']
SQL[SELECT `port_id` FROM `ports` WHERE `device_id` = '995' AND `ifIndex` = '1']
SQL[SELECT COUNT(*) FROM `ipv4_networks` WHERE `ipv4_network` = '127.0.0.1/32']
SQL[UPDATE `ipv4_networks` set `context_name` ='' WHERE `ipv4_network` = '127.0.0.1/32']
sSQL[SELECT `ipv4_network_id` FROM `ipv4_networks` WHERE `ipv4_network` = '127.0.0.1/32']
SQL[SELECT COUNT(*) FROM `ipv4_addresses` WHERE `ipv4_address` = '127.0.0.1' AND `ipv4_prefixlen` = '32' AND `port_id` = '28844' ]
SQL[UPDATE `ipv4_addresses` set `context_name` ='' WHERE `ipv4_address` = '127.0.0.1' AND `ipv4_prefixlen` = '32' AND `port_id` = '28844']
.SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -m IP-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 ipAdEntNetMask.172.30.15.98]
SQL[SELECT COUNT(*) FROM `ports` WHERE device_id = '995' AND `ifIndex` = '2']
SQL[SELECT `port_id` FROM `ports` WHERE `device_id` = '995' AND `ifIndex` = '2']
SQL[SELECT COUNT(*) FROM `ipv4_networks` WHERE `ipv4_network` = '172.30.15.96/28']
SQL[UPDATE `ipv4_networks` set `context_name` ='' WHERE `ipv4_network` = '172.30.15.96/28']
sSQL[SELECT `ipv4_network_id` FROM `ipv4_networks` WHERE `ipv4_network` = '172.30.15.96/28']
SQL[SELECT COUNT(*) FROM `ipv4_addresses` WHERE `ipv4_address` = '172.30.15.98' AND `ipv4_prefixlen` = '28' AND `port_id` = '28845' ]
SQL[UPDATE `ipv4_addresses` set `context_name` ='' WHERE `ipv4_address` = '172.30.15.98' AND `ipv4_prefixlen` = '28' AND `port_id` = '28845']
.SQL[SELECT `ipv4_addresses`.*, `ports`.`device_id`, `ports`.`ifIndex` FROM `ipv4_addresses` LEFT JOIN `ports` ON `ipv4_addresses`.`port_id` = `ports`.`port_id` WHERE `ports`.device_id = '995' OR `ports`.`device_id` IS NULL]
>> Runtime for discovery module 'ipv4-addresses': 0.0880 seconds with 4664 bytes
#### Unload disco module ipv4-addresses ####
Modules status: Global+ OS- Device Module [ ipv6-addresses ] disabled on os.
Modules status: Global- OS- Device Module [ route ] disabled on os.
#### Load disco module sensors ####
Pre-cache poweralert: tlUpsSnmpCardSerialNum SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Ovq -m TRIPPLITE-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.4.1.850.100.1.1.4.0]
Expected IDENTIFIER (_): At line 355 in /opt/librenms/mibs/poweralert/TRIPPLITE-MIB
"2550AV0AC899001645"
Array
[poweralert_serial] => 2550AV0AC899001645
ENTITY-SENSOR: Caching OIDs: entPhysicalDescrSNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m CISCO-ENTITY-SENSOR-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 entPhysicalDescr]
entPhysicalDescr = No Such Object available on this agent at this OID
entPhysicalNameSNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m CISCO-ENTITY-SENSOR-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 entPhysicalName]
entPhysicalName = No Such Object available on this agent at this OID
entPhySensorTypeSNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m ENTITY-SENSOR-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 entPhySensorType]
entPhySensorType = No Such Object available on this agent at this OID
entPhySensorScaleSNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m ENTITY-SENSOR-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 entPhySensorScale]
entPhySensorScale = No Such Object available on this agent at this OID
entPhySensorPrecisionSNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m ENTITY-SENSOR-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 entPhySensorPrecision]
entPhySensorPrecision = No Such Object available on this agent at this OID
entPhySensorValueSNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m ENTITY-SENSOR-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 entPhySensorValue]
entPhySensorValue = No Such Object available on this agent at this OID
SQL[SELECT attrib_value FROM devices_attribs WHERE `device_id` = '995' AND `attrib_type` = 'ipmi_hostname' ]
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class='voltage' AND S.device_id = D.device_id AND D.device_id = '995' AND S.poller_type = 'ipmi']
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class='temperature' AND S.device_id = D.device_id AND D.device_id = '995' AND S.poller_type = 'ipmi']
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class='fanspeed' AND S.device_id = D.device_id AND D.device_id = '995' AND S.poller_type = 'ipmi']
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class='power' AND S.device_id = D.device_id AND D.device_id = '995' AND S.poller_type = 'ipmi']
Airflow: SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class='airflow' AND S.device_id = D.device_id AND D.device_id = '995' AND S.poller_type = 'snmp']
Current: RFC1628 SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -Osqn -m UPS-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.2.6]
.*.*.2.6 No Such Instance currently exists at this OID
SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OsqnU -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.4.3.0]
.*.*.4.3.0 1
.1.3.6.1.2.1.33.1.4.3.0 1
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.4.4.1.3.1]
6
Discover sensor: .1.3.6.1.2.1.33.1.4.4.1.3.1, 1, rfc1628, Output, snmp, 10, 1, , 0.6
SQL[SELECT COUNT(sensor_id) FROM `sensors` WHERE `poller_type`= 'snmp' AND `sensor_class` = 'current' AND `device_id` = '995' AND sensor_type = 'rfc1628' AND `sensor_index` = '1']
SQL[SELECT * FROM `sensors` WHERE `sensor_class` = 'current' AND `device_id` = '995' AND `sensor_type` = 'rfc1628' AND `sensor_index` = '1']
.SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OsqnU -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.3.2.0]
.*.*.3.2.0 1
.1.3.6.1.2.1.33.1.3.2.0 1
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.3.3.1.4.1]
Discover sensor: .1.3.6.1.2.1.33.1.3.3.1.4.1, 101, rfc1628, Input, snmp, 10, 1, , 0
SQL[SELECT COUNT(sensor_id) FROM `sensors` WHERE `poller_type`= 'snmp' AND `sensor_class` = 'current' AND `device_id` = '995' AND sensor_type = 'rfc1628' AND `sensor_index` = '101']
SQL[SELECT * FROM `sensors` WHERE `sensor_class` = 'current' AND `device_id` = '995' AND `sensor_type` = 'rfc1628' AND `sensor_index` = '101']
.SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OsqnU -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.5.2.0]
.*.*.5.2.0 No Such Instance currently exists at this OID
Array
[rfc1628] => Array
[1] => 1
[101] => 1
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class='current' AND S.device_id = D.device_id AND D.device_id = '995' AND S.poller_type = 'snmp']
1 -> rfc1628
101 -> rfc1628
Charge: RFC1628 SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -Osqn -m UPS-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.2.4]
.*.*.2.4.0 100 percent
.1.3.6.1.2.1.33.1.2.4.0 100 percent
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -O vq -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.2.4.0]
100
Discover sensor: .1.3.6.1.2.1.33.1.2.4.0, 500, rfc1628, Battery charge remaining, snmp, 1, 1, , 100
SQL[SELECT COUNT(sensor_id) FROM `sensors` WHERE `poller_type`= 'snmp' AND `sensor_class` = 'charge' AND `device_id` = '995' AND sensor_type = 'rfc1628' AND `sensor_index` = '500']
SQL[SELECT * FROM `sensors` WHERE `sensor_class` = 'charge' AND `device_id` = '995' AND `sensor_type` = 'rfc1628' AND `sensor_index` = '500']
.Array
[rfc1628] => Array
[500] => 1
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class='charge' AND S.device_id = D.device_id AND D.device_id = '995' AND S.poller_type = 'snmp']
500 -> rfc1628
Dbm: SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class='dbm' AND S.device_id = D.device_id AND D.device_id = '995' AND S.poller_type = 'snmp']
Fanspeed: SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class='fanspeed' AND S.device_id = D.device_id AND D.device_id = '995' AND S.poller_type = 'snmp']
Frequency: RFC1628 SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OsqnU -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.3.2.0]
.*.*.3.2.0 1
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.3.3.1.2.1]
598
Discover sensor: .1.3.6.1.2.1.33.1.3.3.1.2.1, 3.2.0.1, rfc1628, Input, snmp, 10, 1, , 59.8
SQL[SELECT COUNT(sensor_id) FROM `sensors` WHERE `poller_type`= 'snmp' AND `sensor_class` = 'frequency' AND `device_id` = '995' AND sensor_type = 'rfc1628' AND `sensor_index` = '3.2.0.1']
SQL[SELECT * FROM `sensors` WHERE `sensor_class` = 'frequency' AND `device_id` = '995' AND `sensor_type` = 'rfc1628' AND `sensor_index` = '3.2.0.1']
.SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.4.2.0]
598
Discover sensor: .1.3.6.1.2.1.33.1.4.2.0, 4.2.0, rfc1628, Output, snmp, 10, 1, , 59.8
SQL[SELECT COUNT(sensor_id) FROM `sensors` WHERE `poller_type`= 'snmp' AND `sensor_class` = 'frequency' AND `device_id` = '995' AND sensor_type = 'rfc1628' AND `sensor_index` = '4.2.0']
SQL[SELECT * FROM `sensors` WHERE `sensor_class` = 'frequency' AND `device_id` = '995' AND `sensor_type` = 'rfc1628' AND `sensor_index` = '4.2.0']
.SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.5.1.0]
Array
[rfc1628] => Array
[3.2.0.1] => 1
[4.2.0] => 1
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class='frequency' AND S.device_id = D.device_id AND D.device_id = '995' AND S.poller_type = 'snmp']
3.2.0.1 -> rfc1628
4.2.0 -> rfc1628
Humidity: SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class='humidity' AND S.device_id = D.device_id AND D.device_id = '995' AND S.poller_type = 'snmp']
Load: RFC1628 SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -Osqn -m UPS-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.4.4.1.5]
.*.*.*.1 37 percent
.1.3.6.1.2.1.33.1.4.4.1.5.1 37 percent
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -O vq -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.4.4.1.5.1]
37
Discover sensor: .1.3.6.1.2.1.33.1.4.4.1.5.1, 501, rfc1628, Percentage load, snmp, 1, 1, , 37
SQL[SELECT COUNT(sensor_id) FROM `sensors` WHERE `poller_type`= 'snmp' AND `sensor_class` = 'load' AND `device_id` = '995' AND sensor_type = 'rfc1628' AND `sensor_index` = '501']
SQL[SELECT * FROM `sensors` WHERE `sensor_class` = 'load' AND `device_id` = '995' AND `sensor_type` = 'rfc1628' AND `sensor_index` = '501']
.Array
[rfc1628] => Array
[501] => 1
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class='load' AND S.device_id = D.device_id AND D.device_id = '995' AND S.poller_type = 'snmp']
501 -> rfc1628
Power: RFC1628 SNMP[/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OsqnU -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.4.3.0]
.*.*.4.3.0 1
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.4.4.1.4.1]
712
Discover sensor: .1.3.6.1.2.1.33.1.4.4.1.4.1, 301, rfc1628, Output, snmp, 1, 1, , 712
SQL[SELECT COUNT(sensor_id) FROM `sensors` WHERE `poller_type`= 'snmp' AND `sensor_class` = 'power' AND `device_id` = '995' AND sensor_type = 'rfc1628' AND `sensor_index` = '301']
SQL[SELECT * FROM `sensors` WHERE `sensor_class` = 'power' AND `device_id` = '995' AND `sensor_type` = 'rfc1628' AND `sensor_index` = '301']
.*.*.3.2.0 1
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.3.3.1.5.1]
Array
[rfc1628] => Array
[301] => 1
SQL[SELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class='power' AND S.device_id = D.device_id AND D.device_id = '995' AND S.poller_type = 'snmp']
301 -> rfc1628
Runtime: RFC1628 SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.2.2.0]
SNMP[/usr/bin/snmpget -v2c -c COMMUNITY -Ovq -M /opt/librenms/mibs:/opt/librenms/mibs/poweralert udp:HOSTNAME:161 .1.3.6.1.2.1.33.1.2.3.0]
15
Discover sensor: .1.3.6.1.2.1.33.1.2.3.0, 200, rfc1628, Estimated battery time remaining, snmp, 1, 1, , 15
SQL[SELECT COUNT(sensor_id) FROM `sensors` WHERE `poller_type`= 'snmp' AND `sensor_class` = 'runtime' AND `device_id` = '995' AND sensor_type = 'rfc1628' AND `sensor_index` = '200']
SQL[SELECT * FROM `sensors` WHERE `sensor_class` = 'runtime' AND `device_id` = '995' AND `sensor_type` = 'rfc1628' AND `sensor_index` = '200']
.Array
[rfc1628] => Array
[200] => 1
