I just upgraded to Ubuntu 20.04 in place and rebooted. I’m now running a supported version of Mariadb.
librenms@librenms:~$ git pull origin master
From https://github.com/librenms/librenms
* branch master -> FETCH_HEAD
Already up to date.
librenms@librenms:~$ git remote
composer
origin
librenms@librenms:~$ ./daily.sh
Fetching new release information OK
Between releases, waiting for newer release
Updating Composer packages OK
Updated from unset to OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
LibreNMS | 21.4.0-55-g4821c2b37
DB Schema | 2020_12_14_091314_create_port_group_port_table (202)
PHP | 7.3.27-9+ubuntu18.04.1+deb.sury.org+1
Python | 3.8.5
MySQL | 10.3.25-MariaDB-0ubuntu0.20.04.1
RRDTool | 1.7.2
SNMP | NET-SNMP 5.8
[OK] Composer Version: 2.0.12
./lnms migrate
librenms@librenms:~$ ./lnms migrate
* Application In Production! *
> yes
Migrating: 2020_12_14_091314_create_port_groups_table
In Connection.php line 678:
SQLSTATE[42S01]: Base table or view already exists: 1050 Table 'port_groups' already exists (SQL: create table `port_groups` (`id` int unsigned not null
auto_increment primary key, `name` varchar(255) not null, `desc` varchar(255) null) default character set utf8mb4 collate 'utf8mb4_unicode_ci')
In Exception.php line 18:
In PDOStatement.php line 112:
