Ubiquiti USW-48-POE detected as Generic MIPS
~1700 seconds to create file for USW-Enterprise-24-PoE, 2.6MB. What is best way to share this?, can’t really pastebin it.
You’re right, snmpbulkwalk stalls and times out part way through on this model (USW-24-POE) as well. All our other models of Unifi switch complete quickly without issues.
I’ve put a post on the Ubiquiti forum to see if this is a known issue…
https://gist.github.com
https://gist.github.com/troffasky/620136d96211916c05ff4817d05f9fdc/raw/7a55c4f9d4bba317557ff94b4e4ede12fcd60f88/usw-enterprise-24-poe.snmprec
I’ve been unable to capture the output of a USW-24-POE unfortunately.
I even tried the early access firmware (7.1.23) and I see the same issue with snmpbulkwalk stalling after a few seconds and timing out, and snmprec hadn’t finished after more than 24 hours. Sorry! (I think it just keeps trying over and over but every attempt times out)
Use ./scripts/collect-snmp-data.php --full -h <hostname> -v <model name or similar>
