Thank you juanquy for passing that info we are actually right in the middle of a refresh for the docs RRDcached. So I will look into adding what you did here.
thanks -
Kev
thanks -
Kev
No problem glad I go to figure out.
BTW: I’m trying to setup sendmail here ,I do remember testing that transport but for some reason stop working . So I un-install it.
I also tried smtp using smtp.office365.com: 587 but when I click on test transport button not email in my inbox.
So my question is ? : what MTA are you using in order to send email alerts, postfix, sendmail. etc??
Do you have your MTA running in the same server Libre is running?
regards JC
just did it on pastebin.com
DISABLE=0
OPTS="-w 1800 -z 1800 -f 3600 -s librenms -j /var/tmp -l unix:/var/run/rrdcache$
MAXWAIT=30
ENABLE_COREFILES=0
can you provide link to the post please?
Doing this from my phone hope it works . If not I will do it tomorrow
got it thank you
Changing my BASE_PATH= to “/opt/librenms/rrd/” fixed it. I obviously missed this when editing my file.
Made all other suggestions here and I’m back to normal:
https://docs.librenms.org/Support/Performance/
Hopefully we’re optimized now
