Unable to see Vlans on RouterOS - Mikrotik devices
root@librenms:/opt/librenms# docker compose exec --user librenms librenms php validate.php
LibreNMS  | 23.5.0 (2023-06-14T22:51:04-04:00)
DB Schema | 2023_05_12_071412_devices_expand_timetaken_doubles (251)
PHP       | 8.1.20
Python    | 3.10.12
Database  | MariaDB 10.11.4-MariaDB-log
SNMP      | 5.9.3
[OK]    Installed from the official Docker image; no Composer required
[OK]    MySQl and PHP time match
[OK]    No python wrapper pollers found
[OK]    Redis is functional
[WARN]  IPv6 is disabled on your server, you will not be able to add IPv6 devices.
[OK]    rrd_dir is writable
[WARN]  Updates are managed through the official Docker image
When adding Mikrotik devices, I"m unable to see the L2 vlans. (Bridge > vlans)
The tab isn’t there at all in LibreNMS.
I added the community of concern as read / write and copied over the LNMS_vlans.scr file to the root folder of each Mikrotik. Still no vlans after re-discover, reboot, or re-adding the device.
