Update 1.56 to 1.65 failed / still reporting as 1.56 after manual db fix
We have auto update turned off on our prod Librenms
I tried maually updating today from 1.56 to 1.65
I did :
git pull https://github.com/librenms/librenms 1.65
./build-base.php
However I got somme errors, same as someone else reported here : /t/lnms-migrate-fails/12335
In Connection.php line 669: SQLSTATE[42000]: Syntax error or access violation: 1091 Can’t DROP ‘deleted’; check that column/key exists (SQL: ALTER TABLE access_points DROP INDEX deleted, ADD INDEX access_points_deleted_index(deleted)
In PDOStatement.php line 129: SQLSTATE[42000]: Syntax error or access violation: 1091 Can’t DROP ‘deleted’; check that column/key exists
PDOStatement.php line 127: SQLSTATE[42000]: Syntax error or access violation: 1091 Can’t DROP ‘deleted’; check that column/key exists
lnms migrate did not solve the pb
So I did what was recommended by the previously mentioned bug report :
insert into migrations (migration, batch) VALUES (“2020_04_06_001048_the_great_index_rename”, 1);
./validate.php
and manually run the ~100+ SQL statements
Now LibreNMS is working but still reporting as v1.56 in GUI and by validate.php :
-bash-4.2$ git pull https://github.com/librenms/librenms 1.65
  • tag 1.65 -> FETCH_HEAD
    Already up-to-date.
-bash-4.2$ ./validate.php
LibreNMS 1.56-1227-g8a6de3e
DB Schema 2020_06_23_00522_alter_availability_perc_column (170)
PHP 7.3.20
Python 3.6.8
MySQL 5.7.30-33
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
[OK] Composer Version: 1.10.9
-bash-4.2$ ./build-base.php
Nothing to migrate.
What can I do to fix?
Corrected itself by temporarily reactivating updates in config.php then running daily.sh
git fetch --tags to fetch the tags.
