fatal: unable to access ‘https://github.com/librenms/librenms.git/’: Encountered end of file
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
Caching Mac OUI data FAIL
Caching Mac OUI
→ Downloading …
Error processing Mac OUI :
Exception: Requests_Exception
cURL error 35: TCP connection reset by peer
-bash-4.2$ git pull
You have a firewall/other network troubles.
Fix those and this issue should solve itself
