Upgraded to php8.5 poller issue?
I have upgraded from php 8.2 to php 8.5 on Debian 12. After upgrade everything appears to be working but ran validate and I am getting some poller errors:
./validate.php
LibreNMS 26.9.1 (2026-09-22T12:33:27-05:00)
DB Schema 2026_09_16_120000_widen_ent_physical_rev_columns (403)
PHP 8.5.11
Python 3.11.2
Database MariaDB 11.4.3-MariaDB-deb12
SNMP 5.9.3
[OK] Composer Version: 2.10.3
[FAIL] The poller is not running. No poller ran in the last 300 seconds.
[OK] No errors found with polling frequencies.
When I go look at the poller info (about it sometimes is green and sometime is red. But it does seem to be running and collecting data.
The poller says PHP is the old 8.2 version which I have uninstalled from the server. I assume this is just a display artifact since it is collecting data? But i’m unsure how to clear the validate errors. Any advice?
Thanks,
Aaron
well, apparently it just need some time to work out its issues. I checked poller an hour ago and it was all green and I rechecked the validate and it no longer complains about poller issues. The wrong PHP version is still showing in poller status but it appears to be happy
