is there a way to use addhost.php to add hosts and in the same line override the Override sysLocation: for that device?
or is there another cli command to set the sysLocation for a given host?
i have about 400 devices to add to librenms, and the syslocations in all the devices arent usable,
so i’d lige to make a script and import them that way.
imho I would suggest making a script to correct the syslocations on the devices itself instead of trying to fix it on librenms side.
It will be a big job but in the end it is better to have the correct info on the source.
